Results 1 to 15 of 19
Thread: What carby is this and would you use it???
    70s Tragic Grease Monkey RA28tragic's Avatar
    Aug 2006
    Default What carby is this and would you use it???
    I found this little teasure in the boot of a 28 I purchased recently. I also bought an 18RC off Jeffro to go in the car. Would it be worth my while putting this acrby on the motor after it is run in?
    img242.imageshack.us/img242/1461/carbyqe8.th.jpg][/url]
    [img=http://img242.imageshack.us/img242/1461/carbyqe8.th.jpg]
    PS It don't fit the rider mowere but the neighbours don't know that.
    Living in the 70s
    Default Re: What carby is this and would you use it???
    Looks like a 40 or a 45, and they work allright on an 18r, I speak from experience, could go even better with a mild camshaft which cost me I think $60 exchange
    Aug 2006
    Do these things have an affective choke? Not that it is a real problem in Rockhampton.
    Living in the 70s
    i think so, your foot on the pedal works just as good
    if it's a weber it'll have the model written on the top of the float bowl lid, on the filter side of the jet cap... see the image below for what i mean
    '77 RA28LT #2 ← 2.2L 18RG...
    Not sure that it is a Weber, pic isn't good enough.
    Could be either a Weber, Dellorto or (Mikuni) Solex.
    They're all pretty much the same in operation, but a Weber will be much easier to find parts for and someone who can tune it for you.
    They're all pretty good for performance when set up properly, not so good for economy.
    I don't want to be a Domestic Engineer bnicho's Avatar
    Looks like a neat setup with linkage and all complete. Nice find.
    If you don't want it, you won't have a problem selling it.
    i had no problems getting jets/kit etc for a delorto DHLA
    and yes i would use it will sound nice
    It should have something writen on the main cover, looks like a Weber which has lost its OEM jet cover. The bump in the top cover is the give away clue, the pump jet pump is under there.
    They have a choke that works if the parts are there. Sometimes the choke mechanism gets removed and blanked off. I cannot tell that from the picture.
    The best way to check the size is to remove the carby from the manifold and measure the bore diameter at the throttle plate.
    Regards
    Rodger
    If you dont have a use for it, Ill give it a good home
    Its a Weber, 100%, easy to tell even with that shitty pic. No way to tell what size it is though (unless you are actually prepaired to read the number stamped on the al casting!).
    There seems to be no linkage to the choke position so its probably been ditched, but if ur running a single DCOE on a non-cross flow engine, you have a lot more to worry about.
    Also cant tell how mis-matched all the jets and venturi's are.
    Just stick it on untill the 18R-C dies and you can afford a 1G.
    oregon
    Redline still shows a kit available for the 18RC! K765. Here is a photo of Redlines kit... intake doesn't look the same... but angle are completely different
    Some useful stuff for Weber owners.....
    http://www.piercemanifolds.com/calpart.pdf - calibration parts
    http://www.piercemanifolds.com/explvwprt.pdf - nearly 8 megs...
    http://www.piercemanifolds.com/Repairkits.htm - rebuild and gasket kits
    http://www.piercemanifolds.com/Float_Level_1.htm - setting floats
    http://www.piercemanifolds.com/Carbu...Adjustment.htm - set up
    http://www.piercemanifolds.com/Addendum.htm - addendum to set up
    The manifold youve already got is better, its a cross-over.
    yeah crossover manifold will be better with a single side draught
    I think the other manifold is made for the american market, where they have a brake booster and master cylinder on that side of the engine bay... so they move the carby forward to account for it (same reason you cant use long runners on 18RGs in early celicas over here)
