i have had some good success with using water, water/ethanol(metho), and water/methanol. you could use the setup with methanol. it absorbs heat like crazy. some extra fuel and lower temps mean heaps more power. i had a water injection setup on a turbo car, which used a small irrigation nozzle. ( 180 degree fan) this worked with a line from the manifold with a 1 way valve in it ( kept pressure in the tank. ) a tank, and a lock off solenoid triggered with a hobbs switch. this worked beautifully. i did have to keep an eye on the tank level. it blew a head gasket once when it ran out. the car ran heaps better and cooler. it used to boil if you flogged it for a while, but after putting the water/methanol in there, i could flog it for as long as i dared.
