Results 16 to 30 of 40
Thread: DIY Water injection
    User Conversion King
    NWA
    Default Re: DIY Water injection
    ill take my chances
    hello
    Apr 2007
    wilcannia NSW
    i have had some good success with using water, water/ethanol(metho), and water/methanol. you could use the setup with methanol. it absorbs heat like crazy. some extra fuel and lower temps mean heaps more power. i had a water injection setup on a turbo car, which used a small irrigation nozzle. ( 180 degree fan) this worked with a line from the manifold with a 1 way valve in it ( kept pressure in the tank. ) a tank, and a lock off solenoid triggered with a hobbs switch. this worked beautifully. i did have to keep an eye on the tank level. it blew a head gasket once when it ran out. the car ran heaps better and cooler. it used to boil if you flogged it for a while, but after putting the water/methanol in there, i could flog it for as long as i dared.
    Oberst Koi-Master Backyard Mechanic
    http://users.frii.com/maphill/wi.html
    http://www.kennedysdynotune.com/waterinjected.htm
    I'll be trying it on my gze when i get motivated... either gunna get a kit from somewhere or make my own as per that first website's recommendations... there's some kits on ebay around 450 mark.
    "Welcome the dude who ain't the buyer of mugs"
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    i would tend to think injecting before a supercharger would help to seal the rotors and lubricate etc. hence increasing efficiency.
    Do it and let us know how it goes. I cant imagine how the minimal amount of water could significantly increase sealing in the supercharger. I'd suggest if thats want you want to do then make a water jacket for the SC casing! This way the SC rotors will expand more than the SC case leading to better sealing and then maybe sc death....
    I have experienced that fine mist water injection pre-supercharger causes the manifold pressure to be a higher by 2 psi on my 4AGZE (with 15psi of boost) but also the torque dropped considerably. I experimented by adding up to about 6 degrees of extra ignition advance to try and get the torque back, and it made little difference - I was too scared to try even more advance.
    What are you thinking about trying differently? My next adventure will be injecting directly after the intercooler.
    Cheers, Nick.
    == 4AGZE SC14 Supercharged ==
    Brett... what are the rotors made of?? Anything other than distilled water will promote wear and destroy seals rather than lubricating. Corrosion is also an issue for long term use (though the coolant idea might fix that)
    When I pulled the supercharger out of my car, I gave it a close inspection, there was no noticeable extra wear. The only sign I could see were 'water marks' on the rotors.
    GT4 Freak, and Conversion King Squid's Avatar
    I stumbled across this:
    http://v6supercharged.com.au/workshop.asp?ProjectID=8
    I am looking at info for my potential WI setup (3sgte) and found this... the problem could just be with the build quality of the holden unit...
    ST185 GrpA #116
    ST165 GT4 Project Car - Soon with v6 goodness.
    The glass is neither half empty nor half full, rather the glass is twice as big as it needs to be.
    personally i'll be headed for something that's kit based, or get the components seperate... i can get the 12vdc 100psi + sureflo pumps for myself through my brother's fish pond business and the nozzles though aquamist etc.
    I cannot justify spending thousands on the conversion and then skimping on something that has the potential to go bad etc.
    It depends on the droplet size. That's why I ran my setup at over 100psi, I sat down and kept winding up the pressure until I got a nice, fine mist out of the sprayer. I'd say that guy was running a sprinkler fitting by the look of it.
    I have run WI on 2 cars now and swear by it. On the GT8 with 10:1 compression i can run 17psi no probs and inlet temps on a power run have yet to pass 35deg C. Previously i have uses Aquamist but i have found their pumps to be a little fragle...nice and light for a race car but for all round use i have moved to a more solid and reliable SurFlo 120psi pump.
    You can't go past the aquamist nozzles though so why bother with the complexity of a rust prone injector? My autronic does the switching but a hobb switch works well enough. There's some argument to go with a load referenced variable flow but in my opinion once you are past peak torque (therefore peak det potential) the water injected is less critical and you can set a simple on/off system up top do this well.
    Canterbury
    With outdoor misting nozzles and 100psi behind it, the mist was no different to what you get out of aquamist...(I have both). Its so fine you can't feel it except for very slight cool feel (in still air) but in 1 second water is dropping copiously off the bottom of your hand...
    the always broken 165 Carport Converter piggy's Avatar
    n.t
    im also considerign using this on my 162 but theres on real room with the topmounted w/a 3sgte so the only issue would be a good place to mount it
    1974 TA22 Celica the new project
    2002 UZS171 Crown daily
    st165 white forged gen2 3sgte 264deg cams, 1000cc injectors, side facing plenum, GT30, CBR600 COP, 205 gbox, diff and calipers, haltech ecu,coilovers, 3'' exhaust, water meth injection 235AWKW @ 22psi 12.29@117MPH 1.885 60'
    piggy - I am putting one in the 165, well planning on it anyway...
    Justen - Wouldn't mind having a chat sometime to discuss the setup for the 165... perhaps at the next beer oclock...
    ST185 GrpA #116
    The advantage of an injector setup is you can map the amount of water, I was running mine to inject around 8% fuel to water all the way through the rev range...
    Ben, aquamist do this with a variable speed pump. As a ducks nuts setup this would be great but the added complexity (for most) over simple on/off setup just isn't worth the ffort in my book. I confident my setup does 95% of what a load referenced flowrate would do. as i said, peak torque is the main consideration so size your jets for that plus a small fudge factor and you're away.
    I see what you mean, but it's a bit like getting rid of all that complicated EFI gear and putting a carbie back on. After all, it's much less complexity and therefore should be much more reliable
  1. Water injection vs Intercooler
    By Gibbon in forum Tech and Conversions
    Last Post: 21-10-2006, 04:57 PM
  2. Cooling Systems - Overheating Problems.
  3. required jet and boost pressure switch for water injection?
    By -=DV=- in forum Tech and Conversions
    Last Post: 30-03-2006, 10:53 AM
