Results 1 to 15 of 28
Thread: ta22 roll cage
    Junior Member Grease Monkey imlach74's Avatar
    victoria
    Default ta22 roll cage
    i have been thinking about a roll cage for my ta22
    thought it wud look cool....and save me when im in shitt
    i want just a 4 point bolt on type one
    are they road legal???
    and also how much wud i bee looking to pay cos i dont have the machines to make one
    Junior Member Backyard Mechanic rob1's Avatar
    Tas
    Default Re: ta22 roll cage
    http://www.bondrollbars.com/
    don't know price but last time i checked a bolt-in half cage was between $400-$600
    in my state a half cage is legal as long as you change the rego to 2 seater and any part of the cage that is within 100mm of your head is padded.
    victoria
    Roll cages are legal, but you have to build it according to some regulations regarding clearances from the head, visability and ease of entry/egress. Provided the cage meets all these requirments you then have to get an engineering approval for rego. Im not sure on the price of a bolt in cage, but you can get one welded in for $1500+ and it will be much stronger than a bolt in cage. You cant get a cams certificate with a bolt in cage anymore, so if your planning on doing any racing a welded in cams approved cage is what you want.
    victoria
    Quote Originally Posted by rob1
    to reggister as a 2 seater im guessing u can only have 2 people in the car meaning backseats goo...........
    sounds like the end of my fun
    Junior Member Grease Monkey Gunna's Avatar
    tasmania
    Not long ago there was a bolt in roll cage for sale on ebay for $200 if someone else knows about it they might be able to help you get in touch with the guy cause im pretty sure it didnt sell... Good luck with it.
    Cheers, Craig...
    Junior Member 1st year Apprentice 3T-GTE's Avatar
    Hey imlach74,
    I might still have a Bond 6-point alloy bolt-in cage available...
    Send me a PM if you'd be interested.
    David.
    Quote Originally Posted by imlach74
    that's a good reason
    Imlach74,
    You need to speak to your local registration body about what is and isn't required in Vic. In NSW there are guidelines in relation to the amount of head room and a TA22 just doesn't have enough to retain the back seat.
    They do look cool tho and more importantly the stiffen up the body for awesome handling.
    Here's some inspiration
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    i just got on for teh 23, was $980 couried to the workshop,
    6 point bolt in type from bonds roll bars,
    1/2 cage was $650 i think...
    you then have option of harness bar $110 and side intrusion bars $110 also,
    if your looking to get into club racing, id recomend it....
    THIS MOTIVATED ME TO GET ONE...
    Quote Originally Posted by psychofox
    I thought I'd share with the Toymods community the Accident I had on the 2/12/06.
    I was doing the Bathurst Light Car Club Speed Weekend, which is a Conrod Straight supersprint on the Saturday and a Mountain Straight hillclimb on the Sunday. Let's just say I didn't make the hillclimb....
    The Supersprint is from about 300m below forest elbow on Conrod Straight, through the Chase, then Murrays and over the start line.
    So I did my first run, a bit tentatively through the chase, but clean. On the Second run I came into the chase, probably doing 170-175km/h into the braking zone, jumped on the brakes, turned in and hit the ripple strip on the inside of the first left hander. The pics can show the rest.
    Pics continued next post
    NOW GO GET ONE LIKE I DID
    Thank F#ck that wasn't a classic celica.
    imlach74,
    My cage in my show TA-22 is a half (4point) Bond alloy cage, but at the time in the mid 80's we ordered ones that suit the RA-28. Reason being, we could place the rear legs down to the wheel arches and hence no compromise to the rear seating.
    ACT rego wanted me to change to a type 2 Rally rego but after seeing the installation granted standard rego, meaning I can keep the rear seat and have rear passengers.
    I'll post up a picture tonight as Image shack is not coming up on my work PC.
    So I recommend getting a steel Bond 4 point that suits an RA-28.
    Regards
    Rodger
    Victoria, Mt Macedon
    Vicroads has a .pdf regarding rollcage installation here.
    The gist of it is that if it is well designed it shouldn't need any inspection or sign off to be legal. Though it seems almost inevtiable that it will need to become a 2 seater.
    However please read the above document and call Vicroads/engineer/roadworthy person if something isn't clear.
    Hen
    victoria
    those pictures aree painfull
    thanks for the info everyonee
    i still really want one just gotta find one at the right price and that fits into the rules etcccc
    if anyone hears of one please PM mee
    THANSKSS
    Finally here is the RA-28 four point alloy Bond cage in my TA-22.
    The legs as stated go down to the rear wheel arches and clears the rear passengers heads.
    I am not sure what Rod has done with his, but they should have an extra brace to the floor of the boot (I believe Bond has these also) or a brace across the underside and donw to the shock towers. Otherwise in a roll over these arms can punch through the parcel shelf and then the fuel tank.
    Regards
    Rodger
    Im very inteested in getting one done but I couldnt bare to wreck my interior..are there any options?
    -Just Alloy Radiators-
    www.alloyradiators.com.au
  1. Roll Center Adjusters
    By Gold28 in forum Tech and Conversions
    Last Post: 19-11-2013, 08:52 PM
