Results 16 to 21 of 21
Thread: Lead stuck in distributor - UPDATE
    Default Re: Lead stuck in distributor
    okay thanks
    i'll give it a go again.. will update as soon as it moves 5mm++ or comes out
    edit : so a few drops of wd-40 would do eh? okay done i'll try all ur suggestions
    so.. kept tugging for a bit last night.. and today a mate had some really small tools to work with, don't mean it in a bad way thanks to edmund (tauhutauhu on toymods) for the tools..
    and we tugged and 2 mins later the shit came out... but.... here's pics..
    the flat end is what we were holding onto... now the other half should look like this...
    and a peek into the distributor showed that the other half is indeed stuck inside there..
    thing is, i put the new lead in, and the car still starts... runs the same... so should i just leave it there? or take the cap off and go a bit further? new cap? try to fuck with it some more??
    Default Re: Lead stuck in distributor - UPDATE
    the bottom might be welded in there now
    is it mangled in there?
    not all leads have the tapered end like you showed..
    i reckon give it a bit of a go...worst thing you could do is feck the cap
    if you ar careful with drill bit (1-2mm smaller than hole (the metal hole inside).. you might break it loose.
    i have a feeling it is welded in as i've tried to move it with a little metal bit, and it wouldn't move anywhere.. not it's not mangled as i didn't fuck it too hard...
    not sure why that's happened.. but it's not leaking any current anywhere now...
    oh well... new cap is now on the (non-priority) list...
    fair enough.. if there is only a little bit left, and the lead doesn't feel like it will fall out (check occasionally in future?).. be ok for now
    victoria
    i told you not to mess with it
  1. Electronic Distributor for 4K Engine
    By Tham in forum Tech and Conversions
    Last Post: 20-07-2006, 08:25 PM
  2. how to lock a distributor?
    Last Post: 14-06-2006, 11:46 AM
  3. 3S-GTE Distributor o-ring
    By Matty P in forum Tech and Conversions
    Last Post: 22-03-2006, 08:27 PM
