Results 16 to 25 of 25
Thread: TRD 4AGE cam gears- Indexed (and 1JZ)
    Default Re: TRD 4AGE cam gears- Indexed (and 1JZ)
    hmm, if you can take or have a pic directly on the end of the dowelled cams, i can try to measure it....
    Toymods Club Member Backyard Mechanic Big T's Avatar
    Does this help?
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
    Penrith BC
    this same principle applies to practiclly all the g headed engines ive seen
    the g heads have 3 holes in the cam gears, and 3 holes in the cam itself. you can vernier as OC has outlined above. this exactly what i did with the 7mge years ago. i have it all plotted out on greasy paper somewhere.
    ../delete/ban
    tech moderator
    Quote Originally Posted by Big T
    using the middle hole as reference
    the right hole is about +39deg = 40 -1 deg or about 1 deg advance
    the left hole is about -39 deg = 40 -1 deg or about 1 deg retard...
    so for fine tuning as Ed says. and yes, it's not new and many people already know how to do it
    i can't remember if K motors had it stock... used to also be for adjusting for cam chain stretch.
    would be interesting to get pics of different gears and cams and ppl can know exactyl how much they are changing it...
    Penrith BC
    the instructions for belt stretch managment dictate only usin the cam gear holes to allow for a bit of extra slop... NOT the cam holes themselves to give vernier increments through use in combination... i guess toyota decided it would get too confusing to include in the workshop manual
    i brought this topic up ages ago in an attempt to convince the hatori hanzo dorrrifto kiddies that they didnt need to spend uber dollars on the purple annodised bling goodness... with(suprisingly) little avail...
    ../delete/ban
    tech moderator
    Quote Originally Posted by ed_jza80
    of course, 90 percent of people buy bling cam wheels for the bling, they wouldn't know cam timing if someone adjusted it on a dyno for them, it produced more usable power then somehow jumped out and bit them in the face!
    they are expensive though arent they
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    How many engine have you seen with flash, expensive cam gears set to zero?
    I know I've seen heaps.....
    Junior Member Domestic Engineer ill-minded's Avatar
    May 2006
    ok well this doesn't really help much (in regards to getting people to realise they don't need the bling) but i got bored last night and started playing in solid edge making some adjustable cam gears. basically, they're made without any measurements, so they aren't for any purpose, but if someone gave me some measurements for a set of gears, i could adjust/redraw them to suit.
    in any case, the picture still looks sexy
    Looks almost identical to my Greddy cam gear
    244rwkw / 328hp @ 18psi
    New Zealand
    love the japlish on that!!
    please, no more PMs!
    Last Post: 17-06-2008, 09:53 PM
  2. 4AGE 86KW TVIS V 100KW 4AGE + Shocks
    By GeeEss in forum Tech and Conversions
    Last Post: 17-01-2007, 09:51 PM
  3. WHEN DID CAMSHAFTS GEARS CHANGE in 18RG?
    Last Post: 02-10-2006, 02:51 PM
