Can you paste the problem in here, non financial members can't view the link
Hi guys,
I really need some help with my Cresta, I bought it a few weeks ago , and changed the headgasket and water pump , all was done with supervision of 3 elite mechanics from these forums.
The problem im faced with now , is the following :
http://toymods.net/forums/showthread...498#post459498
Any help would be great .
I am the sun
From my members ride thread...Originally Posted by coFF33
So there's fuel and spark, the timing might have still slipped a tooth or two after you started cranking it? But even if it was a tooth or two out it should still fire
Put a timing light on it and see that the timing is right when you crank it over, then you can rule it out all together
Did you ever run it before you changed the HG and waterpump?
I am the sun
Maybe it's 180 degrees out mate???
I've done that very thing before.
Just a thought.
I'm not a financial member yet I can view the link?Originally Posted by Dale
1990 JZA70 R - BLMQZ
m a n u a l
Dark green mica
14.118 @ 101.01 mph (Perth Motorplex, 24/05/06)
252.1 HP (Hyperdrive, 11/11/06) / 264.2 HP (XSpeed, 24/02/07)
Dale:
Yeah mate, it worked when we found out about BHG and it also ran before i re-torqued the head again last weeked.
Stradler: ive spoken to Adsport and Matt (Wildsupra) they both believe the dizzy/cam timing is out
im 110% sure the Harmonic Balancer and Cam Cog are both at top dead centre and 1st Piston is at top of engine.
The problem is the dizzy .and the positioning of it and the rotor button .
I need to know if the rotor button spins Clockwise or Anticlockwise to i can setup the button to point just before the first spark lead.
I plan to rip the timing to shreds again tomorrow arvo and re do it all again to be 1000% sure that the timing of cam/crank is perfect and the dizzy is also perfect.
EDIT:
As the tip of the spark plug is wet with fuel i would assume now that either
a: the engine is FLOOOOODED with fuel and cannot spark
or
b: the timing is 180 Degrees off and its sparking when the exhaust side is open
Pull the cap of the dizzy and crank the engine and see which way the rotor spins.
To check your spark timing - to see if it's way out of whack - pull the spark plug out of cyl 1, and crank the engine. Shine a torch down into the cylinder (assuming you can see the piston when it comes TDC) and see if the piston is at the top when the plug sparks.
seeyuzz
river
Good idea river.
But judging with a screwdriver, the piston is all the way at the top.
Just got off the phone to adsport.
He believes that my Rotor button on my Dizzy spins anti clockwise ...
Therefore ive been setting up the dizzy to fire on #2 insted of #1 this whole time.
will correct this when i get home tonite.
all else fails...remove the motor and replace with a 4AC...
im semi serious
Project Soarer II - Sold
Evo 5 - The silver fruitbox
Dont worry matt, its been contemplated .
i have the option of a
1GGZE (missing supercharger) from wildsupra
1GGTE (Hamgatan's over heating one)
or i could just buy a corona ST141 for a few hundred and use the motor from that.
do the rona option
you dont want too many sports cars...as much fun as it is...
rona option would be bugger all...you can get whole cars for under $400
yeah . this is true. but then its a carbi engine conversion from hell!!!!
Too many pipes and shit everywhere ay :s
plus ive just put a new Headgasket and water pump on this engine and cleaned everything up ..
bah ill figure it out , coz tehn once im driving it around , ill know that i put so much effort in and ill appreciate it more![]()
are you joking...seriously...isnt this motor in it carby already?
that wouldnt be an engine conversion...that would be an engine swap
As River said, to be 400% sure which way the rotor spins, take the cap off and crank. Also, doesnt hurt to turn the dizzy around 180 and check for that, often the cam will be at 12 oclock on the exhaust stroke for no. 1... 18RGs are like that and I came unstuck with a 202 that was like that too.
