Results 46 to 60 of 61
Thread: xJZ-Series Engine Variants
  1. #46
    Default Re: xJZ-Series Engine Variants
    Engine model and generation:
    Aristo 2JZ-GTE non-VVTi
    Top End Modifications:
    Mild porting, Bronze valve guides
    Bottom end modifications:
    JE Forged pistons w/ Vertical gas ports, ARP rod bolts etc.
    Forced induction:
    Garrett GT3540R 0.82 Exhaust housing. 6Boost Manifold, Turbonetics RG-45 Wastegate (45mm). 19psi boost.
    Management:
    EMS Stinger.
    Fuel used:
    BP 95
    Intake:
    K&N Pod Filter (can't remember the actual size)
    Exhaust:
    4" dump and exhaust, 4" cat and straight through muffler. +Screamer pipe.
    Driveline:
    W58, F series diff with a truetrac torsen center.
    Other info:
    Custom FMIC, Walbro 550 fuel pump.
    New ISP doesn't provide hosting... zzz... hooray for attachments.
  2. #47
    Cressida 1jz non vvti
    JHH ported head, 280 degree jun cams, springs, retainers
    stock
    Forced induction:
    Garrett t66, 6 boost manifold, 45 turbosmart gate, 17psi (soon to be 22psi)
    Management:
    microtech ltx16
    Fuel used:
    premium
    Intake:
    4" and cheap pod
    Exhaust:
    3" dump 3" exhaust
    Driveline:
    standard mx83 diff, standard a340 with mv valve body, 4000rpm convertor
    Other info:
    Walbro fuel pump, 550cc injectors, sard regulator
  3. #48
    Junior Member Grease Monkey nash's Avatar
    May 2007
    1.5JZ-GE (1J soarer head + 2J NA bottom end)
    Mild port, HKS 264/264 camshafts
    None.
    Forced induction:
    Garrett GT3540R 0.82 Exhaust housing. eBay Made in China Manifold, Turbosmart 44mm Wastegate
    Management:
    Greddy Emanage Ultimate
    Fuel used:
    BP Ultimate 98
    Intake:
    4" K&N
    Exhaust:
    3.5" dump and 3" straight through to 3" Greddy catback (in the shop right now for a bigger twin system)
    Driveline:
    r154,HKS GD-Pro twin plate clutch, TRD 1.5 way LSD
    Other Info:
    Pierburg 360L/hr fuel pump, Sard 850cc injectors
  4. #49
    stock
    Forced induction:
    Garrett t66, 6 boost manifold, 45 turbosmart gate, 21psi
    Management:
    microtech ltx16
    Fuel used:
    premium
    Intake:
    4" and cheap pod
    Exhaust:
    3.5" dump 3.5" exhaust
    Driveline:
    Other info:
  5. #50
    Forced induction:
    Garrett GT3540R 0.82 Exhaust housing. 6Boost Manifold, Turbonetics RG-45 Wastegate (45mm). 22psi boost.
    Management:
    EMS Stinger. EMS 6-Channel CDI, AEM Pencil Coils
    Fuel used:
    BP 98
    Intake:
    Exhaust:
    Driveline:
    Other info:
    Custom FMIC, Walbro 550 fuel pump, Sard 650cc Injectors, Sard Fuel Pressure Reg.
  6. #51
    left handed lion tamer 1st year Apprentice 1.5jzmx83's Avatar
    Apr 2008
    victoria
    1.5jz
    hks 272's
    hks cam gears
    hks head gasket
    ebay inlet manifold
    q45 throttle body
    1200cc injectors
    trust manifold
    trust wastegate
    HKS T04R
    blitz intercooler
    apexi avcr
    ls2 coil packs
    haltech platinum sports 2000 ecu
    results
    451.7KW ATW'S ON 20.44 PSI
    RUNNING ON E85
    needs a stiffer wastegate spring.... with give me about 50kw's more in the midrange
  7. #52
    Jan 2009
    sa
    1jzgte non vvti gen 1
    nill
    nill
    Forced induction:
    rebuild ct12 turbos, steel wheeled
    Management:
    safc 2
    Fuel used:
    BP 98
    Intake:
    hks deathpod, 3 inch intake
    Exhaust:
    2.5" twin dumps till to start of the tailshaft then into 3 inch.
    Driveline:
    r154, heavy duty clutch of unknown origin
    Other info:
    FMIC with 3 inch pipeing, walbro 255 pump, (cannot run more boost due to fuel cut)
    Power: 242.6kw/325.2hp ATW @15psi
  8. #53
    Jun 2009
    nil
    nil
    Forced induction:
    factory 1jz turbos (10psi)
    Management:
    stock
    Fuel used:
    BP 98
    Intake:
    Pod filter
    Exhaust:
    Stock Y-pipe----->2.5inch exhaust
    Driveline:
    W57, 7MGE clutch
    Other info:
    FMIC with 2.25 piping
    Power: 151rwkw@10psi
    Uploaded with ImageShack.us
  9. #54
    stock
    Forced induction:
    Garrett t66, 6 boost manifold, 45 turbosmart gate, 23psi
    Management:
    microtech ltx16
    Fuel used:
    e85 pump
    Intake:
    4" and cheap pod
    Exhaust:
    Driveline:
    Other info:
    2xWalbro fuel pump, 1000cc injectors, sard regulator
  10. #55
    Jan 2008
    VVTi 1jz
    nil
    nil
    Forced induction:
    hypergear highflow
    Management:
    Autronic SM4
    Fuel used:
    BP 98
    Intake:
    K&N Pod filter
    Exhaust:
    AM performance dump, 3 inch, 12 inch straight through muffler
    Driveline:
    JZX100 R154 NPC clutch
    Other info:
    cooler mounted in radiator support, injectors highflowed to 700cc, synapse 40mm wastegate on standard manifold
    Power: 280 rwkw
    turbo/gate/manifold/screamer/lines for sale PM ME
  11. #56
    Aug 2006
    2jzgte
    nil
    nil
    Forced induction:
    garrett to4z. 1.00 rear
    Management:
    ha;tech e11v2
    Fuel used:
    caltex vortex 98
    Intake:
    K&N Pod filter
    Exhaust:
    4in from the turbo to rear of the van. 5in cat with 4in inlet and exit. big 4in muffler
    Driveline:
    built a340. 3400rpm convertor. g series hiace cressida hybrid lsd
    Other info:
    600x300x120 cooler. owner made exhaust manifold, standard inlet manifold, 3in cooler piping. 1000cc precision inj's
    Power: 324 rwkw or 434 rwhp
  12. #57
    stock
    Forced induction:
    Precision pt6765, 6 boost manifold, 45 turbosmart gate, 30psi (567rwhp was t66 at 26psi. 560rwhp was to4z at 28psi)
    Management:
    microtech ltx16
    Fuel used:
    e85 pump
    Intake:
    4" and cheap pod
    Exhaust:
    Driveline:
    standard mx83 diff, built a340 with mv valve body, 4500rpm convertor
    Other info:
    2xWalbro fuel pump, 1600cc injectors, sard regulator
  13. #58
    Jul 2008
    2jzgte 1997 Aristo Engine
    Toyota cressida Mx73
    BC 264 cams
    BC titanium double valve springs
    BPP fuel rail ID1000CC injectors
    SuperSpark Coil Packs
    none
    Forced induction:
    T04z .84 rear 25PSI
    Management:
    Wolf V500
    Fuel used:
    E85
    Intake:
    4" intake
    Exhaust: 4" exhaust
    Driveline:
    A340e
    Other info:
    568hp
    Vehicle was involved in an accident front quarter panel damage. All bits and pieces I have are for sale. But cannot post in the for sale section
  14. #59
    Sep 2007
    NT
    Mx83 Cressida tunes by David from Silverwater Automotive Services. Flew him up from Sydney for a dyno day in Darwin.
    35 degree day with 85% humidity at 8am
    Car made 280rwkw @20psi with more in the tank when I put a new fuel pump and AFM in. Happy days.
    1jz-gte VVTI
    Tomei PonCams
    none
    Forced induction:
    Tomei Arms m8280 turbo kit, custom 3" dump and exhaust. Straight through with high flow cat
    Management.
    Apexi Power FC
    Fuel used:
    United boost98
    Intake:
    4" K&N pod
    Exhaust:
    3" dump pipe, 3" cat, 3" exhaust, 3" straight through muffler.
    Driveline:
    stock a341e with rebuilt mx83 diff running 4:11 gearing
    Other info:
    PWR FMIC, 3" cooler piping, 850cc injectors, walbro 255 fuel pump maxed SARD Fuel rail, trans cooler.
  15. #60
    Toyota cressida mx83 1992
    2jz-gte non VVTI ex jzs147
    none
    none
    Forced induction:
    Precision 6262 .82 rear, turbosmart hypergate 45, 2.5 inch piping through ebay cooler
    Management:
    Wolf v500 tuned by dale at castle hill performance centre
    Fuel used:
    Bp ultimate 98
    Intake:
    4" super cheap pod
    Exhaust:
    3" dump pipe, 3" cat, 3" exhaust, 3" sports muffler and res
    Driveline:
    mv 2800 stall and 1.5 shift kit a341
    Other info:
    Top feed 850cc denso injectors, turbosmart fpr800 , walbro 255 intank
    242rwkw @ 14psi apparently fuel pump and coils are not up to scratch
    (need to scan dyno sheet)
  1. sticky dyno results thread
    By chris davey in forum Toymods Car Club Membership and Feedback
    Last Post: 20-06-2007, 06:07 PM
  2. Toymods Dyno Day 13 - Sunday, July 2nd
    Last Post: 21-07-2006, 12:32 PM
  3. Dyno Day 12 - Final Results!
    Last Post: 23-02-2006, 11:12 PM
  4. Dyno Day 12 - results thus far...
    Last Post: 28-01-2006, 12:35 PM
  5. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 10:46 PM
