HiOriginally Posted by TTMX83
I changed the capacitors in the guys car that started this thread and his car has been fine for about 2 weeks now with lots of driving, so we are both confident that it is fixed.
Are you sure the ecu you tried is a good one? I only ask because 3 out of his 6 or so capacitors were leaking very badly so its wasn't just a random one off dodgy capacitor.
It's fair to presume that most 1J ecu's of that age with those particular capacitors could be leaking.
When his car was playing up it was sending huge amounts of excess fuel into some cylinders, so much that it was coming out the exhaust still as a liquid. Try a LED test light on each signal wire at the injectors while the car is idling and see if some have a very short pulse (normal) and others have a very long or continuous pulse (not normal)
If the pulses are not approximately the same for all cylinders (but still a pulse) you have a stuffed ecu. If some injectors are on continuously you have a problem with the wiring for the injectors or a stuffed ecu.
