Results 16 to 20 of 20
Thread: nice looking cam removal tool!
    Default Re: nice looking cam removal tool!
    see, i was thinking more along the lines of...
    since you can hold the cam caps down, without the valve springs pushing them up, then you can torque the cam caps more accurately..
    and you can make sure it is in position and such before making it all tight..
    i should have said, it's a cam installing tool.. not removing
    heavy springs + big lift = cam pushing in funny directions when you try to torque it up?
    what? Automotive Encyclopaedia EVOSTi's Avatar
    meh ive never torqued cam caps and ive done a shit load of them. i think someone from the old forum had a go at me about that once? ohwell never had a problem.
    Junior Member Backyard Mechanic leso's Avatar
    well if it's a tool to remove/install cams ...how come it doesn't go on top of all the bearing caps ??? me thinks it's some thing to do with something else>>> maybe checking valve timing or lift. Dont think them pissy little springs would hold down cams..just a thought..
    cam removal tool from WST range of Tools. Quality tools is there motto i think?!
    also very well priced for automotive tooling.
    Black Betty >HERE!<
    (\__/)
    well, the problem with the beemer cams.. is that they are hollow
    and the reason it doesn't go ontop all the caps is... it's a 4cyl version, but if you rotate the cam to a certain spot, the 1 and 6 cyl lobes are not pushing onthe valves.. so you can use the 4cyl version
    and here is a writeup about using it, or not using it etc...
    http://www.pelicanparts.com/bmw/tech...ft-removal.htm
  1. Replies: 22
    Last Post: 28-08-2008, 05:49 PM
  2. Removal of MZ21 EMV screen
    By 4agerolla in forum Tech and Conversions
    Last Post: 18-06-2006, 08:33 AM
  3. Should i buy a Clutch aglinment tool?
    Last Post: 18-04-2006, 06:41 PM
