Page 2 of 10 FirstFirst 1234 ... LastLast
Results 16 to 30 of 136
Thread: 1JZ ECU capacitor replacement info
    Default Re: 1JZ ECU capacitor replacement info
    I know nothing about electronics but those things sure do look stuffed!
    QUICKEST 1JZ'S IN OZ
    The Fonz Grease Monkey rob_o's Avatar
    Awesome write-up!
    I'm having issues with my car (injectors) and I'm pretty sure this is the issue. I cracked open my ECU and one of the capacitors are leaking.
    I don't have a steady hand to do this, but my dad said he may give it a go...
    Give you $20 to do mine?
    1JZ Toyota Cressida Grande
    Turboholic Grease Monkey VeeP's Avatar
    could the damaged caps have anything to do with an overly (like filthy) rich mixture the whole way through the rev range?
    '88 Soarer GT-L
    '90 Supra Aerotop
    So is it just 1Js that suffer this or are a bunch of mid90s Toyotas likely to be in that bracket too?
    I've seen leaking caps in AE101 20V ecu's too.
    Any ECU with Nichicon branded capacitors on the board, from around that era.
    Rich mixture could be from MAP sensor, O2 sensor, intake air temp sensor, coolant temp sensor, or crook ECU, or probably other things too.
    Have you pulled your ECU codes to see if it has thrown any?
    244rwkw / 328hp @ 18psi
    yeah pulled the codes but it didnt give me any - apparently everythng is finnnneee!!
    is there a reference table for pressure vs map output voltage or resistance or however the unit works?
    '88 Soarer GT-L
    '90 Supra Aerotop
    Someone recently did a study on various map sensors, might want to check with him to see if he wrote down the voltages at each pressure level.
    I got error code 14 (IGF I think it is) and 21 (O2 Sensor - however it's unplugged so we know that problem).
    Ribfeast - wanna replace my capacitors? lol. I'm shit when it comes to electronics.
    If you feel liking driving up to newy with the ECU sometime lol
    Chiba
    If you're looking for a replacement 15uF capacitor, goto RS Components and ask for part number 491-0412. It's a 15uF, 63V Nichicon. Come as packs of 5 and should be available off the shelf.
    Now. Try to find a 20uF cap for the AE101 4AGZE ECU. That's a hard one.... Everything is always 22uF.
    Some great info in this thread ... thanks
    How crucial are the ripple current specs for these caps? What about the other specs such as impedence?
    I have some Rubycon ML series caps here, which are only 75mA ripple current (compared to 250mA for the ZL series or 480mA for the ZAs)
    I guess it wouldn't be very hard to source the 'right' ones, but if what I have would be OK then I may as well use them up.
    '93 MX83 Cressy with 1JZGTE (now with engineered goodness)
    '85 YN57 Hilux SR5 with 3.8l V6
    '98 ES300 (with gold bits!!)
    + A Corolla and some non-Toyotas
    Chiba
    They will be better than what's in there, that's for sure. Obviously the ZL are better, but for this application, I doubt it matters much. You're not exactly smoothing power for the latest intel processor...
    there will be many reps coming your way for this, i have 1 leaking cap, thank fuck its not more
    now off to suck wilbo's knob so he'll solder mine up
    The boobs are back
    Chiba
    I can have a look if you can get it Brisbane southside if you want. Got a heap of spare caps too, stinking minimum purchase quantities.....
  1. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 07:27 PM
  2. max safe power on 1JZ with std injectors and ecu (with FCD)??
    By RORZ_JZA70 in forum Tech and Conversions
    Last Post: 14-08-2006, 12:59 PM
  3. 1JZGTE ECU Part Numbers
    Last Post: 13-02-2006, 11:31 AM
