Results 16 to 24 of 24
Thread: 4age build
    Default Re: 4age build
    7A-FE head gaskets fit on 4A-GEs?
    would a 4AGE head fit on a 7a short motor, has this been tried?
    Junior Member Backyard Mechanic kugzs's Avatar
    Got good condition 23/28 bonnet hinges? pm me
    AB
    Quote Originally Posted by wraith
    Call me old fashioned, just trying to support local business.
    Genuine Toyota stuff can be quite well priced, and will likely perform well in his application.
    So, while I may not have said 'do this and this and get a fully hektik dorifto racecar d00d111eleven1, I did attempt to contribute in a meaningful fashion toward the initial question. Thank you for your interest in keeping these forums full of potentially useful information.
    Ash
    Now that post made sense. EDIT: I was trying to quote Wraith's previous post but some thing wrong with the system today and quoted this one.
    7A-GE's have been done many times google it and you will see.
    I don't know how much i would trust 20v pistons in a 16v. valve clearances maybe "close" on a mock up but think about a torqued and then retorqued gasket..... its just one of those situations where if your trying to build a solid motor a "maybe" is just not good enough.
    Quote Originally Posted by merc-blue
    Cheap tools take all the fun out of working on a car.
    My Rebuild and Conversion.... '81 Tercel 3A -> 4A-GE 20 Valve - ON HOLD.
    BAD ASS 1986 MR2 - Finally Moving forward.
    thanks, interesting information, but I wouldnt be prepared to spend the dollars on rods.
    oregon
    Forged pistons are heavier than cast... If there is no NEED for a forged pistons then it isn't doing it right the first time. There IS a factory 1/2mm oversize 4AGE piston that raises compression from 9.4 to 10.0 WITHOUT having to worry about pin fitment. This piston is the Euro/Singapore 4AGE... NOT 4AGEC... the Euro/Singapore pistons are 10 to 1. The 1990+ Redtop piston is 10.3 to 1, not 10.5.
    The part # for the 10 to 1 O/S piston is - 13103-16030. The proper ring set for that piston is 13013-16180
    are these available through Toyota Australia or would they be something to search out on the web?
    Is the compression ratio the main reason for the small port AE92 being more powerful than the big port AE82 or does the port size make a big difference?
    oregon
    Quote Originally Posted by wa5
    You'd likely have to find them... you could try AEU86.org... someone there might be able to get them... also home market might be able to get them too...
    Compression bump is usually good for a few hp... and I've heard that the small port head adds a few as well
    Strange ****** Grease Monkey wraith's Avatar
    Have you pulled the engine apart yet? The later model bigports had a 7 rib block & 42mm crank journals- just checked the one in the shed...
    Ash
    WTB- replacement titanium nuts to suit the squirrel on my Megaswarf 2300. Carbon fiber model, not the Chinese knockoff fiberglass.
    AB
    Quote Originally Posted by oldeskewltoy
    smallport is better as long as your target is under 200hp after that bigport is the way to go as it will flow much better.
    definately make sure your matching up pin sizes on your rods if your planning on new pistons other wise you might end up in a situation where your changing pistons, rods and crank. early bigports are 18mm wrist and 40mm crank, later models are 20mm wrist and 42mm crank.
    Last Post: 17-06-2008, 09:53 PM
  2. 4AGE 86KW TVIS V 100KW 4AGE + Shocks
    By GeeEss in forum Tech and Conversions
    Last Post: 17-01-2007, 09:51 PM
  3. big port 4age comparisom
    By General_Bupkiss in forum Tech and Conversions
    Last Post: 03-04-2006, 09:12 PM
  4. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 05:51 PM
