Results 16 to 20 of 20
Thread: 4AGE noise found...
    Default Re: 4AGE noise found...
    Quote Originally Posted by Mr Revhead
    as mentioned above, 16v 4ages dont run PCV valves
    im pretty sure my 20valve does though, why not run them on 16V and run them on 20v ?
    What is autosalon? Sounds kinda homo.
    Quote Originally Posted by tooch
    It's extremely homo. Basically a whole lot of sh1t cars, with ugly wheels, and a lot of 16-20 year old rockstars with trendy mullets and gay shirts.
    Slayer Of Toymods Wookie Slayers
    New Zealand
    yes the 20v does
    prob due to different emissions laws they were made to conform too.
    could have been an engineering desicion though
    please, no more PMs!
    Ok, 16v 4AGEs definitely don't run a PCV valve. The port on the plenum that connects to the cam cover actually follows a passageway on the inside of the plenum up to the throttle body, & vents about 1-2mm in front of the butterfly, so at idle/closed throttle there really should be very little vacuum sucking the crank case gases in.
    With the cut & shut plenum there's no saying what has been done to this setup. Perhaps someone's stuck a drill through the port on the plenum & givin it max vac?
    Easiest solution, hook up a catch can with a filter on it.
    Next easiest, do the same as above but hook it back up to the inlet in front of the throttle body.
    Hardest solution, pull off theplenum/intake manifold & work out what's been done to it, then go from there.
    S.A
    turbo... thats should increase the crankcase pressure a bit
    Works every time !!
    Sheebz Automotive Grease Monkey Gleno28's Avatar
    Cheers guys, see how i go!
    Glen.
    A lone crusader, in a dangerous world of low reputation...
    ST141 Corona, VZN130 4Runner, 4AGE KE70 Pan Van
    18RG RA28
    1GGZE RA28
  1. 4AGE 100kW Dizzy Oil Leak Guide
    By Talasas in forum Tech and Conversions
    Last Post: 05-11-2014, 08:00 PM
  2. Which injectors for which 4AGE bigport ECU
    By Grega in forum Tech and Conversions
    Last Post: 04-08-2006, 06:49 PM
