Results 1 to 6 of 6
Thread: Disassembling Three-piece Wheels
    Junior Member Automotive Encyclopaedia 011's Avatar
    Default Disassembling Three-piece Wheels
    Hi gang,
    I have some Work three piece wheels and I'd like to get the centres resprayed in a different colour.
    I figured that I could unbolt the centres from the other two pieces and take the centrepiece to a shop and get it done that way. It would be easier than taking a whole wheel.
    Is there a special procedure for bolting the centres back onto the wheel (or unbolting, even), and what should I torque the centrepiece 'rivets' to?
    Should I give Simmons a call and see what they say?
    Thanks heaps,
    Dylan
    Latest news on my adub!
    > august 15 New brakes the next thing. Otherwise, it's quick, shiny and reliable. Enjoying every drive. =D And my car's becoming a bit of a celebrity!
    Default Re: Disassembling Three-piece Wheels
    give NEALES WHEELS A CALL
    9642 1002
    they are the people to speak to about wheels in sydney
    Tasmania
    Mate they are easy to pull apart just undo the bolts and then tap the centre witha rubber mallet.
    I don't want to be a Domestic Engineer bnicho's Avatar
    Make sure you mark the centre's position in relation to the outer rims somehow, and that each centre goes back into the original rims in the same positions. Otherwise you WILL have serious balancing issues. The centres and rims of Simmons are selectively balanced at the factory.
    Brett Nicholson (bnicho) - Greendale, Victoria
    I own Corollas, Crowns, Prados and
    Various leaking British things...
    Thanks. That was one of the things I was sort of after - specialised things to consider.
    Tasmania
    Mate I've pulled 3 sets apart and had them painted etc and all you have to worry about is the tyre valve in some cases and that's it. If you want to mark it all up etc then go for it but there really is no need IMO. That's speaking from experience. Good luck with it it is almost impossible to stuff up unless you over tighten the bolts when you put them back together.
    Rich
  1. Painting My Wheels..
    By puzzle man in forum Tech and Conversions
    Last Post: 29-09-2006, 12:22 AM
  2. inverted 3 piece wheels...
    By sticky667 in forum Tech and Conversions
    Last Post: 29-07-2006, 10:31 AM
