Results 1 to 5 of 5
Thread: xa6x xz1x adjustable rear ends
    Forum Sponsor Conversion King
    Default xa6x xz1x adjustable rear ends
    im think about building rose and heim jointed rear ends for these things just wanted to if there would be interest.
    yes they will be noisier than stock but will also hold the geometry better than rubber and urethane.
    i will also be making alloy cradle bushes/pineapples
    advantages: when springs are out you will be able to move the swing arm throught its full arc with no binding, will be camber and toe adjustable, set and forget.
    disadvatages. noise but if you take the car to the track who cares.
    Default Re: xa6x xz1x adjustable rear ends
    Can you do a sketch of what you are planning ?
    Are you going to modify existing trailing arms or create new ones?
    If you're going to modify the bush ends of the arm, you may as well address mount points for coil-overs and springs ... (waits for Wilbo to put up link to his pics of MA61/MZ10 trailing arm travel)
    ask whathe i barely have the skills to put up a post.
    i was planning to use the orig arms and mod them to suit with a heim joint in the outer.
    then use an adjustable rose joint on the inner to change toe then mod the bar to allow for camber adj using plates and bolts to secure it all so it doesnt move.
    i wont get around to doing mine for about two weeks but when i do ill take some pics.
    By The Witzl in forum FAQ
  2. xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
    By CrUZida in forum Tech and Conversions
    Last Post: 24-07-2018, 11:43 PM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
