Results 16 to 24 of 24
Thread: wtf is going on? Wheels still move when in gear?
    Default Re: wtf is going on? Wheels still move when in gear?
    open her up... look to see if it has helical gears, or spider gears.
    Actually, my RC buggy has Torsen LSDs, and they use straight cut gears... same principal, just need thicker oil.
    EDIT... pretty sure torsen should turn both wheels the same way with the car on stands and turning the tailshaft by hand... whereas open will spin opposite (unless the torsen is out of oil)
    Bit hard when you're going to inspect a car to buy...
    Any other ways?
    The traditional method is a bit hard when the owner is in the passenger seat
    Otherwise, one wheel on soft, one on hard, about a second of full throttle, and see if theres a black mark from the tyre on the hard surface... if not, then shes open or sloppy. If theres a black mark, its LSD. Should be evident pretty quickly, as non LSD you wont go very far (do it with the brakes off).
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    well i ripp 2 wheel marks all the time and when its up on the stand it acts like a torson or what ever its called,
    i will open up when car comes off the road soon
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
    Any other ways?
    hmm... i though tyou could jack one wheel up and then see if it span or not..
    actually.. i could go and check huh maybe when it's not midnight
    awww come on. Where's your sense of adventure
    hey i just got home from uni at 2am.... and it's less than 10 deg outside.... and it's almost summer
    tomorrow if i get home befor elight....
    middle diff is viscous?
    yeah yeah. whinge & complain.
    I'm pretty sure the centre diff is viscous. You shouldn't be abel to slip that by hand.
    ASL? Backyard Mechanic thegreatestben's Avatar
    Feb 2007
    I dunno if its been covered or not but if you want to check if your car has a factory lsd the last number on the trans/axle number will be odd. (3=2 pinion lsd, 5=4 pinion lsd)
    If its got an aftermarket lsd surely the behaviour of the car will let you know fairly easily
  1. Replies: 2
    Last Post: 10-03-2009, 04:29 PM
  2. Edit: Car wont move now, when in gear :(
    By Koffee-Black in forum Tech and Conversions
    Last Post: 17-01-2006, 07:16 PM
  3. changing wheels on ke70
    By spoon in forum Tech and Conversions
    Last Post: 04-01-2006, 07:47 PM
