Results 1 to 5 of 5
Thread: 1jz auto box has issues?
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    Default 1jz auto box has issues?
    I just finished a 1jz conversion and now i think my auto box has some issues, when you drive the car normal it shift gears very hard but when you put your foot down it shift nicely, also seems to shudder a bit on take off from a stand still. anyone have any ideas?
    oh and its a jzx81 setup.
    Pete
    wa
    Default Re: 1jz auto box has issues?
    does it need the toyota type 4 fluid???
    stiff uni joint or driveline angle
    penrith nsw
    has the toyota type 4 in it, the shudder seems more from the box, but what worries me most is the really hard shifting at lower speeds
    Have you played around with the auto line pressure cable that runs off the throttle. It's probably set really tight, or it might be stuck. I know my one got stuck, wouldn't release back, and it chirped on gear changes with stuff all throttle.
    Toyota Corolla Conquest 2003 black manual 1ZZ-FE - Daily
    Toyota Soarer GT-TL 1991 white auto 1JZ-GTE - [email protected] 1.587 60'
    My JZZ30 SOARER
    penrith nsw
    found the problem, kicked cable was set up on the cruise control pulley, changed it over now its runnig perfect.
  1. 1JZ performance head build. Advice/help?
    Last Post: 09-07-2007, 08:08 PM
  2. 1jz to 2jz
    By HIZOKU in forum Tech and Conversions
    Last Post: 30-11-2006, 06:52 AM
  3. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
  4. Occasional harsh downshift on auto
    Last Post: 30-05-2006, 10:36 AM
  5. 1jz vs 2jz heads
