1. do a search.. lots of 7M information around.. some accompanied with good endings.. mostly unreliable.. but there are a few good ones still holding up.. at least 3 comes to mind, that's making reliable power..
2. 1JZ ftw
3. ....?
4. profit?
head studs, head bolts... same thing.. the bolts that hold the head down to the block... this is the crucial bit in preventing BHG.. getting new studs / bolts, tensioning them correctly and properly.. i think they have to be re torqued after u've fitted the head as well, and this is very important in preventing BHG.. i should know this as i've been negged for shitting the 7M.. they aren't bad engines.. as i was once told they are the father of the 2JZ engines.. but the fact of the matter is, for a 3.0 6 cylinder, they are a bit lazy and need a bit of persuasion to get going.. but if you build it right and tune it properly i don't see why it should give you any dramas.. keep in mind though they are getting old now, and the 2JZ is a lot more modern and reliable for making higher power than the 7M and that's a fact u're going to have to face..
hm... 335 to 400 reliable rwhp with a GT35 or GT3540? erm... with a bit of work.. yea why not.. might be running a higher level of boost though, so i'd suggest a thick (1.4 or 1.6mm) metal HG just to be safe, and get it done by a professional or look for tips and suggestions of the 7M owners here![]()
