depends if you ceramic coat the combustion chambers, valves(edit) and ports too eh?
more heat in combustion chamber = less compression/timing needed, but maybe same power? (since heat in gas = power).. as for octane... that depends on heat generated/present during the compression stroke (unless you have hotspots)
in theory![]()
 which means you are LESS likely to have pre-ignition...... hmmmmmm
