well. i suppose you are usually limited to the fuel quality, which in turn determines the maximum dynamic compression you can run... higher gas temp or boost or static compression or lower overlap cams will all increase dynamic compression...
i don't know if it would actually increase or decrease the gas temp prior to ignition.. from my understanding, it could go either way, depending on the heat generated during compression and the heat flux from the walls...
intention to boost? of coursenot sure there is a huge amount to gain in an NA motor (where things seem to take care of themselves pretty well anyway)..
i suppose one way to test it would be to assemble motor, wind in timing till it pings, then coat everything, and do same.. and see which requires less timing.. that will tell you which has higher burn rate..
but changing compression ratios to determine which is best is a little expensive for my liking.... UNLESS you have a boosted motor, and then changing your dynamic compression is as easy as a bleed valve or larger pulley..
yes it's a generalised number and engine dependant but.... you are assuming that knock only happens prior to TDC... doesn't it also occur after TDC (from that net available paper on detecting knock signals)Originally Posted by mic*
i suppose the only way to truly tell would be to assemble identical engines with and without coatings.. test.. and see what happens... but that is beyond the scope of mere mortals with bank accounts...
however.. if you do coat an engine, and then after dyno testing at same boost levels (with same turbo/SC as someone else) and you find that you need 3psi less boost and 5deg less timing to make same power.. then you have a pretty good case... but i think it will only be small gains like this... i would be more interested in longevity of things like rings.. which tend to have a habit of making a mess of things...
