Results 16 to 25 of 25
Thread: 3tgte prolonged fuel problem?
    Junior Member Grease Monkey The GW's Avatar
    Ballarat
    Default Re: 3tgte prolonged fuel problem?
    drove it around (boosting occasionally) yesterday, went fine for the most part, very smooth and good power delivery, starting get down around 3/4s of a tank.
    Noticed a little stutter on take off once, then around 5 mins later i cornered hard and it had a big stutter, then power kicked straight back in..It drove fine on the way home
    1984 SA63 Celica - RIP , 1979 Ford XD - The Lunar Lander
    1972 TA22 Celica - Project Car ,1986 ST162 Celica SX - Gone
    1985 RA65 Celica - Me & ryleys rally car
    1974 TA22 Celica - Current project, 1972 TA22 - Wetish
    Hoppers Crossing
    sounds like a leaning out condition.
    what size are your fuel lines out of interest?
    um, the backfiring though may lend itself to an ignition fault. as you've an aftermarket ECU - how is the ignition triggering being done - via the dizzy or via crank wheel/pickup? i'd be interested to know if when you get to one of these stall conditions what/where your timing is at - the ECU might be pouring in fuel at a retarded ignition situation?
    just my 2c. i hate finding gremlins...
    Ballarat
    yeah its a really old haltech system so its not the best. whilst its been stalled and i havent been able to start it, i just tried the old wacking a spark plug in a lead and cranking the engine over, and it was certainly arking fine...not sure if this is a enough to rule out an ignition fault though. the ignition is triggered off the dizzy
    cheers grega, yeah this gremlin is particularly frustrating, ive come so far with the car to have this happen ill check the size of the fuel lines asap. im assuming theyll be ok because the car has had a 3tgte in it for a long time before i got it and was apparently running high boost...
    Hoppers Crossing
    grant, don't discount an ignition problem mate. just coz its got spark doesn't mean that your ignition firing events are happening correctly.
    how is your pickup done for spark - CAS or crank wheel?
    Ballarat
    thanks heaps for the direction grega, it appears you could well be right on it not be a fuel problem.
    i was dicking around with ryley the other night and was flashing my high beams at him, and noticed a change in the fuel pump sound whenever i did it. when onceNA was redoing doing my intake piping (thanks dude) he checked the alternator for me and found it was around 11 with the lights on.
    so this would make sense considering it has most of its problems as night (when lights are on) and after about 20 mins of driving (when thermo fan kicks in and out).
    only thing it doesnt explain is why it appears to 'surge' around corners..either way i will replace the alt and see how it goes
    cheers dude
    Hoppers Crossing
    grant. check you have good clean earths both to the body and the motor. i was thinking about this yesterday.
    (my ae92 levin used to have a problem where it would fly then all of a sudden cut out, run shit, hardly idle) - turned out i had a loose earth strap.
    so make sure connections to the battery are clean (that your terminals are good ect) and that your earths are secure.
    Ballarat
    will do mate thanks. i was thinking of throwing another earth strap off the battery just to sure
    Hoppers Crossing
    whats the go?
    A while back I had a problem with fuelling in my 3T - can't remember if it had the same effect as yours but it might be something to consider. I seem to remember an irregular idle.
    The mechanic said it was a bad idea to have a powerful pump as a pre-pump to the surge tank and then another efi pump as the main - he said it was over-pressurising the fuel and causing it to cavitate. I was just trying to ensure there was enough fuel getting to the surge tank and didn't realise it could have that effect (I now have a high flow/low pressure pre-pump)
    Don't know if this is what's happening with yours but it could explain the richness - being due to the really high pressure. the time lag could be from the system slowly getting more and more pressurised.
    Anyway, just a thought
    Nov 2008
    queensland
    Mmmmm sounds to me like that some one has done some work
    on the tank maybe put in new fuel lines or reorganised the lines when
    putting in new fuel pumps or surge tank. I am thinking they inadvertinly
    reconnected the fuel lines into and out of the tank incorrectly. Sounds
    likey you now have fuel pick-up and fuel return mixed up or crossed
    over thats why you flame out at 3/4 of at tank, the fuel return pipe only
    extends 1/4 of the way down into the tank and the fuel pickup extends
    to near the bottom of the tank.
    I could be wrong, my #@*%!&# RA28 is still in the shed.
    1 X RA28 CELICA - PROJECT (I have problems of my own)
  1. 4ac not getting fuel
    By Wedged'86 in forum Tech and Conversions
    Last Post: 18-04-2007, 08:57 PM
  2. RA 60 Fuel Gauge Problem
    By restorolla in forum Tech and Conversions
    Last Post: 26-08-2006, 03:15 AM
  3. Car dying all of a sudden - Fuel pump?
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 28-05-2006, 12:27 PM
  4. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
  5. Replies: 1
