KE10's do, but i thought KE30 rolla on had headlight relays?
Ahh, yes, there is a relay for the headlights, but it doesnt do what you think...
Main power for the headlights still does run all the way back to the stalk.
An example:
Measure the voltage across the actual headlight globe when its on, and youll find its a decent amount lower than the battery voltage.
Youll also find that a globe thats 10% down on voltage might be 40% down on brightness.
I installed a Bosch headlight boost kit on my Starlet and then my GT4.
Its basically a couple of relays and new thick wire (factory wire was about 1/4 the size) to replace the factory system.
It made a big difference in headlight brightness.
Daily: Toyota '05 Rav4 Sport
I may just run a relay for the high beam and relay for the low beam and give
them direct battery voltage since my lights are poo. Also what other cars
have the same reflector as the ae86?
can you get Hella inserts? they tend to have good reflectors and lenses
I ran 100/90w globes in my AE86 Japanese Levin spec housings for years without an issue. Was always a little nervous about it though. When the loom came out later, there was no evidence of heat damage. Also always ran uprated 80 / 100w inserts in my TA22 and various Datsun 1600's prior to that.
Subsequently I bought a GTV underdash and accessory loom and found that it had evidence of heat damage at the globe plugs and also the lights junction box under the dash. I presume this had come about from running higher than standard wattage globes.
In future I will be running a separate relayed power supply. Simple enough to do, and cheap insurance.
I wonder with the move to lower wattage / cooler running globes in buildings, when will this technology hit automotive applications, or has it already?
Cam mountain I feel different from the ordinary
Hid.......
There was a 100W driving light option, for the inside globes, for the 70-77 Celicas. I was under the impression the wiring was capable of handling this power. But, these cars being old now, I think it's best to upgrade your wiring to the headlights if you are going to vastly increase their wattage.
However, unless you are doing a lot of night driving in the country, where 100W spotlights would be the best option, I can't see the need for anything more powerful than the usual 50-60W globes.
seeyuzz
river
On the trueno you can, havent seen them for the levin/adm headlights.
Oh yes, you are correct. Best thing you can probably do then is clean the inside of the housings, upgrade wiring with relays for high and low beam and run the plus 50 or plus 60 bulbs.
Callum
