Results 1 to 6 of 6
Thread: turbo oil restrictor
    victoria
    Default turbo oil restrictor
    howdy peoples
    Now for something completly different.
    Im putting a turbo on a six cylinder perkins, and i just need to know what size oil restrictor to run on the inlet to the turbo. the turbo is a T3 of an old saab, and the generator is running around 50psi of oil pressure when hot.
    anybody know?
    Junior Member Grease Monkey Jonny Rochester's Avatar
    Tasmania
    Default Re: turbo oil restrictor
    Go the the garrett website and you can see the specs of each turbo. I think the full 50psi should be fine. If it starts leaking oil and blowing smoke you will have to go back to 35psi. I think the specs will say minimum 29psi when at full load, or something like that.
    victoria
    cheerzs big earzs
    Check this thread. And in particular post number 18.
    ^^ good article that (in post 18), never seen it before.
    when i did my gte i filled the brass fitting that goes into the turbo with solder and drilled a 1.5mm hole in it. i think i seen the 1.5mm mentioned on various threads years ago in different forums.
    victoria
    yeah, if i hadnt got any info i was gonna go ther 1.5 -i also picked up that size from somewhere(zoom?) but i wanted to confirm. its all done and running now, pushing 150Kva
  1. twincharging prototypes needing constructive critisism (SC14 + turbo)
    Last Post: 11-10-2014, 12:02 AM
  2. tips for turbo manifold design
    Last Post: 03-05-2009, 06:47 PM
  3. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 10:12 PM
  4. Damaged turbo
    Last Post: 28-04-2006, 07:42 PM
