here is mine of an efi 2T-G
they look identical to 3T-GTE but the top cover points in a different direction.
fonzy
Yeah I have a spare 3T-GTE one in excelent condition, it may be worth more attached to the motor though
fonzy
deepdishfactory
I got back in touch with another Toyota dealer and they wouldn't even help without the VIN off the orignal car that the motor was from.
I am trying sleeka spares in adelaide they were the guys that rebuilt the motor, hopefully they have contacts.
NAJJE,
Your looking for a part for an import only engine thats over 20 years old. Optimistic is na understatement. Get your hands on a good second hand one and be thankful you found one at all.![]()
1971 2T-B Celica TA22 ST.
1975 2T-G Celica TA27 GT
1985 3F Auto FJ62 Landcruiser
I know you right, I am thankfull the entire motor had parts available when it was rebuilt, I just thought this would be more available then the other parts.
It sounds like Toyota can source these parts, I just need a VIN for a toyota carina import or something else that had the same Thermostat housing possibly a TA22 GT with a 2T-G in it
Not being optimistic or anything![]()
Check the VIN plate thread, I also think I posted a Carina VIN number around here somewhere just need to see if I can find it.
Last post in this thread -
http://www.toymods.net/forums/showthread.php?t=6447
And the VIN gallery -
http://www.toymods.net/forums/showthread.php?t=789
Callum
Callum,
Thanks very much for the info. I contacted Toyota and supplied a TA63 VIN which helped them look for the part.
They no longer stock the Base of the thermostat, only the top which costs a whopping $103.35!!!!
I have now spoken with David from sleeka spares who will try find either a new 3T-GTE or 2-TG housing.
Once again thanks for your help
Rob
hey, have you tried:
Toyota performance & conversions
S. Moloney
03 9428 5277, 65 Butler St. Richmond, Vic 3121
and I.D.B Auto
03 9428 5446
dont know if these are still relevant addresses, but, I found these when i was reading through past mags "Street 4s" edition No3. the mag has Jeff Egans 74 celica with a rally 2T motor and Michael Crocketts 66 corona with an 18R-G
fonzy
deepdishfactory
From experiance, I spoke to Ian at IDB a couple of weeks ago. He is a top fella and extremely helpful. Don't know where Sean Molony has gone these days though. I am pretty sure Sean worked at IDB in the nineties. And also a toyota twin cam guru.
definitely worth ringing both the numbers though!
From what I can remember IDB was still going to be around but I think Sean was giving it away. That was a few years ago when I was ordering some bearings from Sean. I could be wrong, its happened in the past.![]()
Neil.
RA40 3t-gte. Haltech fitted.
Power - 229hp at 17psi![]()
Sean has retired, soob.
IDB is prob first place you should look. If they dont have one maybe have leads to whom would have couple lying around although I would think that is quite rare these days.
For info Sean was an engine builder for Maclaren F1 team in late 70's when turbos were the go. He leased an engine building workshop inside IDB after moving to Aus. He specialised in the Toyota twin cam/turbo technology.
