Currently looking at a Wilwood solution for my AW11.
Wilwood 4pot Dynalites + BP10 Pads
RDA580 Rotors - SW20 258x25 or slotted versions.
From my initial calculations, they should be pretty close to bolt on for the front. I'm planning to make a mock up of the rotors and calipers soon and do a test fit to see if they are going to work and clear 15" rims. For the rears, I'll probably go with the old SW20T rear calipers with AW11 front rotor setup.
EDIT: RDA580 rotors will need a ring spacers to fit the 54mm hub, and 4x100 pattern drilled but that's no big issue. oping to be able to get the 580's as blanks and drill them to suit.
