Page 5 of 392 FirstFirst ... 345671555105 ... LastLast
Results 61 to 75 of 5875
  1. #61
    Mr RA23 raises a very valid point!
    I'll do some investigations into the depth the oil SHOULD be in an 18RC and compare it to what it should be for an 18R-G... and what the 33012 dipstick reads when used in an 18R-G.
    As for Mr RA 28 here....
    well buddy i certainly hope to see it out at dubbo!
    I dont think i'll be finishing my 18R-GTE for Dubbo this year, but i'll have a shot I'll definitely be on for next year though!
    I'll also be interested to see how your cams perferm with the combination you are using.
  2. #62
    I am not yet a Grease Monkey RA23's Avatar
    Sorry Witzl, I spoke to soon. Even though there is an issue with the part numbers of the dipstick, the actual depth appears to be the same. I overfilled it with oil because I got the conversion between quarts and litres wrong :-(
    Anyway, I drained it and filled it again with the proper amount and it is spot on with the 18RC stick.
  3. #63
    Oh well... that saves me a whole heap of effort then!!
    I've got a few more useful parts to photograph and post up, along with some more information that's of good use.
  4. #64
    Junior Member Domestic Engineer tricky's Avatar
    Quote Originally Posted by Steve M
    You wouldn't have a suitable timing inspection cover because you bought an 18RGEU cover for an 18RG.
    Did you get the gasket that attaches block breather to the block? Man those things are a bitch to remove!
    Block breather? Where be the block breather? Does anyone have a pic?
    No, my inspection cover is definitely an 88210 item on an 88210 head. There just isn't any king of inspection cover gasket in the kit.
  5. #65
    Quote Originally Posted by tricky
    That is the plate with the bit of pipe sticking out just above the oil filter. BTW the gasket is toyota part no 11273-33010
  6. #66
    also, a VRS set is nothing below the head, the definition of VRS is Valve Regrind Set, so theres a VRS, which has HG, VSS, manifold gaskets ect ect
    and a Full gasket set, which has the same but also has sump/timing cover ect ect
    The boobs are back
  7. #67
    Quote Originally Posted by RA23
    The plate covering the aux shaft? Mine doesn't have a breather from here, just a plate...
    Mr DOHC, I should add that the list I made of gaskets not included applies to the full gasket set, part no. GK690, as opposed to the VRS, DK690.
    Steve, my block breather gasket (If we are indeed speaking of the same thing) was a piece of piss to get off. The old gasket was cork, so no probs there.
    EDIT: Sorry about the shite pic, but are we talking about the same thing?
  8. #68
    that should have a little pipe coming of it going to the inlet manifold
    i have a few spare
    The boobs are back
  9. #69
    RC has no breather
    RG does
  10. #70
    Quote Originally Posted by Mr DOHC
    i have a few spare
    Do you wanna PM me with a price?
  11. #71
    Strictly speaking, that part is not really needed. As long as you've got the tappet cover breather flowing well, you shouldn't have any troubles with the engine.
    I removed one before so that it would look like all the emmossion points were still linked up and active for registration purposes.
    One thing I would suggest for all 18RG owners is a catch can, especially when using ramflo filters with the tappet cover breather plumbed into the back of the filters.
    We had a few issues with oil vapour soaking the air filters.
    With a catch can with a great deal of stainless steel scourer in there to catch the vapour, we haven't had half the problem we had before.
    I will add this though, make sure that the PCV system does vent correctly because if it doesn't, you lose your dipstick as it flies out of its hole and sprays oil all over your engine bay.
    (\__/)
    (")_(")
  12. #72
    yes, and all over your very hot extractors
    The boobs are back
  13. #73
    hi i have 2 18rg heads cams one inlet manifold and one exhaust manifold i am goin to put them onto my 18r block which has only done 92000km since new lol i was wondering if n e one use fellors had the other stuf i would need to bolt it onto the block eg timing cover. and wat should i do bout my dizzy? im a beginer
    thanks heeps leroy
  14. #74
    u need an aux shaft, timing cover, block breather {not needed really}, dipstick onthe other side, u should really get an oil sender put in to the mount on the side of the motor
    The boobs are back
  15. #75
    chains and guides too
    The boobs are back
