Page 387 of 392 FirstFirst ... 287337377385386387388389 ... LastLast
Results 5,791 to 5,805 of 5875
  1. #5791
    I'm running a 92mm Cometic, ARP Astron head studs and 14psi boost. No issues and over 1000kms of use (fair bit of that on the dyno)
  2. #5792
    Sydney N.S.W
    Gents,
    as per a few pages back, the discussion with coil packs for 18rg's
    ATM fleebay has them available.
    http://www.ebay.com.au/itm/BOSCH-IGN...IBAF#vi-ilComp
    or http://www.ebay.com.au/itm/BOSCH-IGN...4AAOSwr41XIBG0
    Geez i wanna set...
    please delete if this notification is not allowed.
  3. #5793
    Aug 2010
    S.E.Q.
    So how can I work this in with my current breakerless bosh distributor & crane xr700 box ?
    Owen, the other Owen.
  4. #5794
    Owen, I am after a set of turbo forged pistons and know of Arias or Cometic, what specs did you use to order them or off the shelf? I'm after 92mm 8.5 CR, sound about right?
    Yes the old Celica's are great cars thanks..
    76 RA23 18RG
    85 GSXR 750 05 GSXR 750 77 RD400
  5. #5795
    Jun 2010
    New South Wales
    18RG into Celica RA60 auto.
    I have a RA60 Celica with a 21RC engine that is way beyond sluggish. I also have an 18RG motor with a mid-bowl sump that I want to install in the RA 60 to replace the 21RC boat anchor. I will need to get an 18R front bowl sump and oil pick-up to make the engine fit. I am comfortable with this.
    My question is this: can I mate the 21R auto transmission to the 18RG engine? To use a manual transmission will greatly complicate my project.
    Any advice will be appreciated
  6. #5796
    Feb 2012
    Australia
    Quote Originally Posted by Nevakikamukau View Post
    Bellhousing wise, yes, you can use the auto with the same bellhousing. May have to modify some dowels but other then that it'll bolt onto it. An issue you may have is finding the right flex plate. If you are lucky everything from the back of the 21RC will bolt straight on.
    Manual isn't that difficult though, especially keeping it carby.
    NooB 3TGTE swapped RA40
    ✨Rahgo2:Turbo Boogaloo✨
  7. #5797
    Jun 2010
    New South Wales
    Quote Originally Posted by MarcusEstevez View Post
    Thanks for that info Marcus. I am hoping that the flex plate will also fit as the 18RG is shown as an alternate engine in the car's owners handbook. I will eventually convert it to manual as I have the W50 gearbox with the 18RG motor that I have. The auto hook up will get me going for the time being. I am currently trying to locate a front bowl sump and manual pedal box.
    Thanks again
  8. #5798
    Does the 18RG motor or any of its variants have a steel crank or are they all cast?
  9. #5799
    Feb 2012
    Australia
    I've heard rumours of some 18RG's having steel cranks, but never seen any in person, or even photos...
  10. #5800
    Thanks Marcus. I have been searching the web as i too have heard rumors of such a thing but there is no definite answer that i have come across as yet. There are some photos floating around on google image search but as to their authenticity or even being able to verify that its actually an 18RG is quite challenging. Hopefully i can find one or have one made that does no cost exorbitant amounts of money as i am lookin to build an 18RGEU with forced induction. I may just end up nitriding a standard crank if i cant find one. probably the cheaper option.
  11. #5801
    Feb 2012
    Australia
    I think the standard crank can handle it mate. I've never heard of anyone bending or breaking crankshafts with boost. Just get forged pistons and decent rods.
  12. #5802
    likewise - never heard of the cranks failing in these motors.
    I'm building one that should be >400HP on a stock crank. Zero concern over the crank
  13. #5803
    Nov 2013
    CA
    can anyone help me identify these pistons....
    they came out of an RG i just bought...
  14. #5804
    Nov 2013
    CA
    Found them!
  15. #5805
    Sep 2007
    Georgia
    18RG 2000 cc 10.5:1 3.5mm 198-6096PS
    This was the information in the 1990 TRD catalog so great find since they possibly are 10.5:1 pistons which would be a challenge for a turbo charged engine without the correct cams or cam timing. Good post, sorry that I couldn't come up with the answer when asked.
    Make sure you now check the cams that came in that engine build!
    Brown: Turbo application
    Yellow: Rally or Auto Cross
    Gray: Race application
    Source: HKS Ad from 1984
