Good news on the jets and pressure.
Have a great trip to Sydney and enjoy Toyfeast.
Just for closure on my issue earlier..
We welded a bung into the exhaust and found that while my car was lean, it wasn't as drastically bad as the dyno suggested.
I was running
Main jet - 135
Main air - 175
Pilot - 65
Replacing the main air with a 160 instantly made the car run through the rev range much more cleanly without running out of steam in the top end. However the AFR were still heading up to 16 with wide open throttle.
I then put in the 145 main jets and it runs through the rev range better again, and the AFR's spend their time around 14.
My carby guru thinks I could probably go to 150's, but I will leave it alone for the moment and see how it goes to Sydney and back at these settings.
Fuel pressure appears fine on a gauge, so I think the issue was just lean mixtures and a dodgy dyno reading blowing things out of proportion (and maybe my stress too!)
Rgds, Willofan
ditch carbies
go EFI
.... never look back.
Seriously, my EFi 18RG, even in hektik busted arse form, was waaaaay better than any carby 18RG ive driven.
It would have to be ITBs to make me swap to EFI. The reason i like the carbies is for the induction noise even if it does cost a little hp and efficiency compared to EFI.
found why the carby was shooting flame out of it and a host of other issues...............didnt set the timing.........................*facepalm*
RT104 with 4AGTE
Some assembly required
Ahh this old chestnut.....
Fixed for you.....
Well tuned carbs will perform as good as EFI, especially in regards to the old school EFI that was used back in the 70s. Carbies however need to be tweaked and tuned often. If this is too difficult for you, or too expensive to get done regularly, then go EFI.
seeyuzz
river
It's a rare engine - don't sell itThat is not a stamping mistake.
HI folks. CAn any one tell me what I would need to ask for at repco to get a temp sender for my carb 18rg?
AM in Sydney and broke mine...
coolant temp sender should be the same as the 18R-C item. Same thread, and goes to the same gauge.
Stumbled across this on Import Monster
link in case anyone is keen
http://www.importmonster.com.au/view...%20Turbo%2018R
According to the broken english description, the vendor says it came off an 18RGEU
Rens, are there any other numbers following the 0004 in your engine number or do you have the 4th 10R ever made??
(\__/)
(")_(")
