Results 16 to 18 of 18
Thread: I question about Mags....
    Forum Member Grease Monkey TwentyTwo's Avatar
    Default Re: I question about Mags....
    I found that 205's just fitted on the front of my TA22, only problem was hitting a decent bump at full lock with a bit of speed. In that case though, rubbing tyres is the least of your worries. The tyres would contact the inside of the wheel-arch on the front, not on the actual front guard panel or strut. Make sure you test fit the tyres at all lock angles ;-)
    I swapped them for some softer compound 195/60/14's (Falken Azinis RT-205) which had much more grip than I was game to exploit and were probably cheaper than Eagers.
    If anything, having 235 section tyres on a 930kg TA22 would be detrimental to the handling of the car.
    Montrose
    Having Bogan Tyres with white writing full stop is detrimental to the handling of a car! However, it CAN look fat - just don't try to put TOO much tyre on the rim, or it looks just plain silly (e.g. to those that put 275s on an MA61 rim). If you think your steering is easy, then you're not running enough caster. Try those 235s with about 7 degrees caster and you might think differently...
    Western Aus
    TA22's weigh in at:
    GT - 1005 kg
    ST - 985 kg
    LT - Automatic 980 kg
    - Manual 970 kg
    Ripped from Toymods Articles.
    Eldar.O.
    Last Post: 17-06-2008, 08:53 PM
  2. Question on short word searching?
    By dave368 in forum Toymods Car Club Membership and Feedback
    Last Post: 04-03-2007, 04:32 PM
  3. Conversion Question?
    By Uzi3L in forum Tech and Conversions
    Last Post: 08-03-2006, 02:20 PM
  4. Another noob 18RG question
    By tricky in forum Tech and Conversions
    Last Post: 22-02-2006, 12:37 AM
  5. Re-drilling mags...
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 28-10-2005, 07:41 PM
