I have an Altezza 6 speed gearbox ready and waiting to go in. But seeing as you're in NZ it might work out more economical to source one over there.
Apart from that I've done a Gen 2 3SGE into a Datsun 1600 which wouldn't be too dissimilar to putting it into an AE86.
The whole RWD conversion is a bit of a bugger of a job, but would probably be made a whole lot easier if you can find (and afford) a RWD Altezza motor in the first place.
On the fuel pump front I would probably go with a regular EFI pump and run a return line as these are relatively cheap and easy to find when you need to replace it.
Glen (Celica RA45) may make an appearance here and offer you some advice. He's done a bunch of BEAMS motors into his RA45 Celica.
