That's all Gen 1 data. Some of it's useful however.Originally Posted by mgfe
Peter
Originally Posted by DigitalPho3nix
ecu's would be the same, as was only released in japan. I think alot of the power difference would come down to the differnces between the three generations of 1g
I know the 3rd series has (slighty) bigger cams, turbos and a harder tune(more boost).
all these things would help the power levels, but i suspect that once you get serious and start bolting on larger turbos, manifolds and shit like that you would get the same power out of different motors, providing they had equal compression and clearances.
GA23(never finished-now with cracked block) JZX83 (Tyre eater) 3sgte AE86. by now i should know better.
Peter
oIC
havnt heard of that before!!
how do you tell the difference in the 3 generations??
it goes into detail on one of the old threads, serach under 1ggte gen, but from memory.
grey ecu plugs, green injectors -gen 1
yellow ecu plugs, green injectors- gen2
yellow ecu plugs, yellow injectors-gen3
correct me if im wrong enyone?
Originally Posted by Herus
Andrew,
Search and ye will find:
http://www.toymods.net/forums/showthread.php?t=12903
http://www.toymods.net/forums/showthread.php?p=439598
1971 2T-B Celica TA22 ST.
1975 2T-G Celica TA27 GT
1985 3F Auto FJ62 Landcruiser
Totally wrongOriginally Posted by celicapain
Gen1 - Yellow Plugs, Yellow Injectors
Gen2 - Yellow Plugs, Yellow Injectors
Gen3 - Grey plugs (although can be yellow), Green Injectors
Gen1 and Gen2 are pin compatible, but the Gen1 ECU will complain there is no water pump![]()
oh well, at least i got the colours right
cut me some slack i looked at that at least six months ago
p.s cheers for the correction.
Haha, but ya didn't.Not a worry, happy to clarify.
ha thnaks guys
I seccond that. You can have yellow plugs on the ECU and have a gen3...It took me a few months to get to the bottom of what gen mein was..thanks Nathan
Not a problemo![]()
Hey Nathan I posted up my part number for the Blitz BAG turbos in the other tread...when you can have lookie at your part number to compare....
