Results 16 to 30 of 57
Thread: 1GGTE Engine GOOD or BAD??????? Thoughts??
    Default Re: 1GGTE Engine GOOD or BAD??????? Thoughts??
    Ask you local engineer whats legal first, before i recommend a McLaren developed S70.
    Eltham vic
    Quote Originally Posted by mgfe
    ok what else then??
    hi matt
    the commodore v6 is a good one for a hi lux
    plenty of kits around and there is an ecu that has been developed for that conversion
    also you can get lexcen rocker covers and that makes it all toyota
    ian
    Quote Originally Posted by Screamn_Sleeka
    Because they make power above 5,000rpm, not the place u sit at when driving a ute.
    From what ive seen they dont last when worked hard, and are ditched for JZ's.
    Its an inline 6, weight dristrobution is going to move forward.
    Parts are hard to get.
    They smell funny.
    Above 3k they're fine, and they're not terrible when loaded up because they spool a bit faster.
    They last fine, mine is testament, it's been caned for about 25000km since blowing its head gasket, and the dude at the head shop said that was purely because it was sitting around for 5 years.
    They're not much longer than a 22R and they are lighter.
    Parts aren't that hard to get, particularly for the application in mind, it depends what you want to do with it.
    Aug 2006
    hmm ok
    ian dont really want a commodore engine....
    want a tough toyota engine instead!!
    has anyone done one who lives here in Melb??
    still not sure............
    TAS
    Is it school holidays again?
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    Quote Originally Posted by Stefan
    In all seriousness Stefan,
    I had pretty well the same question myself.
    Ive been watching Infotechplus and his conversion with a lot of interest, and have even started getting a few of the bits and pieces together.
    I was also starting to wonder which way i should go. Should i install a 1GGTE, and what are its good and bad points? or should i go with the most likely less powerful 1GGZE, thats going to be good for the general workhorse?
    I have been looking into it for quite a while, and was considering making a thread like this myself.
    The conversion i was looking for had to be 90% bolt in. I dont have access to a welder, and dont particulary want to go making custom engine mounts. I also wanted a cheap, reliable 5 Speed, and an engine that was going to make enough power if i wanted it, but also have the ability to be a nice daily driver.
    The 1G is perfect for this Conversion, as you can bolt the engine straight in, can fit a W58, at not to expensive a cost, and if you want, theres nice easy mods out there that can get you a bit more power with adjustable cam gears, etc.
    Keep the good and bad points coming thanks guys.
    Andrew
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
    Junior Member Backyard Mechanic SIKTOY's Avatar
    I think some guys are on the wrong forums with all this holden talk (there is no need to swear)
    if your looking for a motor with torque go with a 1UZ but if you just want a motor you can thrash go the 1GGTE
    but remember 1G's are getting harder to get parts for so what may seem cheep at first will not end that way
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
    TAS
    It's not so much the questions themselves, but the manner in which they are asked
    Feb 2007
    What kind of mods are needed to bolt in a 1UZ-FE?
    The only one ive seen is millsi's, and im not going that far!
    Is it a simple use a couple of mounts from a different car and away we go?
    or is it harder then that?
    Then if you want a manual, you have to find the right bellhousing, get a slightly stronger gearbox then a W58, unless your going to treat it nice.
    Thanks
    Andrew
    Andrew the W58 is more than strong enough for a 1UZ as for bolting one in I cant help sorry mate
    Cleveland QLD
    Off topic a little bit but I hope you dont mind. i am considering a conversion on my wifes IS200 which has a 1GFE in it . Would the 1GGTE be a wortwhile proposition. I quess it is of the same family/block with a true twincam head an tubocharged. Would it be a good thing and an easier conversion than a 1UZFE? You help would be appreciated.
    CROSSPLANE CRANK! Domestic Engineer Merudo's Avatar
    Quote Originally Posted by TheToyman75
    No such thing as a low Fuss engine conversion
    1JZ into Z20 Soarer?
    TAS
    Quote Originally Posted by toddw
    Any 1GGTE you find will have been made years before your 1GFE, which makes in an illegal swap as far as I know (older engine into newer car).
    I suppose you could go the 'turboed high comp NA motor with good tuning' route with 1G parts, but I have no idea of the feasibility. I seem to remember there being supercharger kits for the 1GFE too, but I might be wrong.
    The 1UZ into a hilux wil not e a bolt in swap, BUT if you want a good torque Toyota motor I personally think its worth the extra $$ and effort.
    The 1G-GTE tho has been put in a few hiluxs and compared to a 22RE will feel like a V8 anyway
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Aug 2006
    hmmmmmmmmmmmmmm
    i dont want much hassles
    just want best torque power easiest option that will last
  1. MA70 --> JZA70 Conversion
  2. Engineers Cert. Question.
    By Mk3_supra in forum Tech and Conversions
    Last Post: 07-03-2007, 10:49 PM
  3. 1ggte engine number?
    Last Post: 28-11-2006, 12:22 PM
