Results 1 to 15 of 24
Thread: 6MGE vs 5MGE crank pulley
    Default 6MGE vs 5MGE crank pulley
    I thought I would quickly list the differences betweent he 6mge and 5mge crank pullies!
    I'm in need of a 6mge crank pulley currently, so I went to the wreckers to see how close a MX73 5mge crank pulley would be...
    EPC:
    MS125 6MGE-Crank Pulley 13407-43020
    MX73 5MGE-Crank Pulley 13407-42020
    MS125 6MGE-Crank Pulley Bolt 90105-18003 (Same as 7MGTE and 7MGE)
    MX73 5MGE-Crank Pulley Bolt 90105-18002
    Notes:
    *Pulley ID (where the crank goes) on the 6mge is larger (~34mm vs ~32mm?)
    *The belt sections are the same (V, V, 7-Rib)
    *In relation to where the belts run if a 5mge pulley is mounted to a 6mge the pulley extends much further outward than a correct 6mge pulley, conversely if one tried to mount a 6mge pulley to a 5mge it would try and sit inside the cylinder for cyl 1 (too far in)
    *The crank pulley section that mounts on the crank is recessed deeper into the pulley on the 5mge, so that the length of pulley on the crank is roughly the same for 5mge and 6mge, just the offset if different
    My understanding is that the 7mge one has the same dimensions as 6mge, but different belts to 6mge (7mge is all ribbed belts)...
    Some pics stolen from the internet...
    6mge:
    5mge:
    Default Re: 6MGE vs 5MGE crank pulley
    i recall one of the guys at the February club meeting saying the crank pulleys were different (varying snout sizes) across the M-series.
    Umm, Wilbo, why does your EPC say MX73 instead of MZ12 ?
    Junior Member Backyard Mechanic STR8 2.8's Avatar
    on a side note, 5mge and 5me pulleys are different too. the snouts are different lengths but the same sizes
    I have a Crown
    Urgh I meant to have MX73 as 5mge of course! (fixed now).
    My EPC doesn't show MZ12
    Junior Member Automotive Encyclopaedia HKS_TRD's Avatar
    May 2006
    Earth Beta
    I could be wrong but arent there 2 different 5M-GE pulleys too? The early verison of the 5M-GE 82-84 or whatever had a different fan belt setup IIRC so perhaps had a different pulley too?
    Quote Originally Posted by HKS_TRD
    correct, i even had to go back to my posts on the old forum, but early 5mge's had a twin v-belt setup and later 5mge's had a 5pk belt setup
    I have a Crown
    it wasnt a big end wilbo??
    THE OFFICIAL TOYMODS BOGAN
    MA61 - sunroof., 7MGTE, 4.11 lsd, w58
    MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
    LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
    Quote Originally Posted by Robbos_Toyotas
    Hellz no.
    Btw if anyone wants to take pics of early / late 5mge pullies that would be cool
    fark me dead - whats wrong with the pulley?
    Sorry, this is the best picture i have of a 6MGE crank pulley
    5M/6M's are known for flogging out the keyway in the crank pulley which rattles around and sounds exactly like a munted big end bearing. This is exactly what happened to my old 6M shortly before I sold it.
    Domestic Godess, NOT Domestic Engineer clubagreenie's Avatar
    There is 2 different 5mge pulleys as described, v and ribbed/v.
    The rib belt is for P/s, alt and fan, outside v pulley is for A/c, the inside not sure but I only ran the ribbed belt.
    FYI to fit late 5mge into ms55 crown you need to turn the outside pulley off to clear the sway bar.
    Friends
    Quote Originally Posted by clubagreenie
    Not from factory.
    From factory the p/s runs off the inside v pulley.
    Heya mate,
    I've taken some pics for ya mate
    Frist photo is from a 5M-E MX73. I know you didn't ask for it...but I added it for interest, it looks very similar to the late model 5MGE I have.
    Second Pic and Third Pic is of a late model 5MGE. Not sure on the source, think it was mz11 or something...
    And lastly a pic of the pulley in a 5MGE (MA61). (Unfortunately its in the car so can't take a good photo of it...)
    Rudi
    Hellz no.
  1. 4AGZE - EA Falcon Pulley Mod
    By TooF in forum Tech and Conversions
    Last Post: 15-05-2006, 12:23 PM
  2. Stuck crank pulley bolt
    By Shifty in forum Tech and Conversions
    Last Post: 05-04-2006, 09:37 AM
  3. 4ag crank pulley sizes
    Last Post: 08-02-2006, 06:27 PM
