Page 3 of 3 FirstFirst 123
Results 31 to 36 of 36
Thread: Safe boost level for a 1jz turbo's
    Western Aus
    Default Re: Safe boost level for a 1jz turbo's
    so you've got and extra few PSI over me due to having no cat? i dont think so.
    Elmo.
    Apr 2007
    Perth
    why not?
    when changing from a stock exhaust to a 3" exhaust on any turbo car there is a usually a gain of 2-3psi, why would removing a highly restrictive cat and replacing it with a straight thru piece of 3" pipe not make a diffrence aswell?
    Cressyskidder Grease Monkey Bowlsclubboy's Avatar
    Albury NSW
    If you put a good size cooler on and a nice exhaust, then the boost naturally increases, i dont see why removing a restriction such as a cat wouldnt have the same effect.
    1992 MX83 Cressida Grande-1JZ-GTE...Actively Dori.
    Western Aus
    well, ill go outside and take a picture of my exhaust, and you'll see why his lack of cat makes no difference.
    oh wait, i dont need to, ill just tell you, i dont have a cat either.
    Elmo.
    Apr 2007
    Perth
    well why didnt u say that in the begining then?
    I'm gonna blame my FMIC then 600x300x100mm apart from that i can c no reason why my car runs 13-15psi with no boost controlling device and all new vacume hoses.
    Western Aus
    i didnt say it because you said having no cat was the reason your running more boost...
    i also did say, first off, that your exhaust was pretty much the same as mine, the only difference being where stuff is positioned, bends etc.
    id be inclined to think it was the cooler too, as theres not much more different.
    Elmo.
  1. Safe Boost For 7mgte
    By itchybum1 in forum Tech and Conversions
    Last Post: 01-05-2006, 12:52 PM
  2. 1JZ boost cut
    By mumblezzz in forum Tech and Conversions
    Last Post: 11-04-2006, 11:35 AM
  3. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 03:53 PM
  4. Replies: 22
    Last Post: 15-03-2006, 01:24 AM
