Results 16 to 25 of 25
Thread: My temp gauge hit max for like 1 second, whats the go?
    I like Cheese Backyard Mechanic Jackel's Avatar
    W.A.
    Default Re: My temp gauge hit max for like 1 second, whats the go?
    Which ever the single wire one is.
    yep then thats the one thanks dude
    Western Aus
    yellow wire with a green stripe through it.
    for everyone else... if it shoots up after you've given the car a bit of stick, turned it off, then back on again a little while later, that'll be heat soak.
    if your driving along and its going up and down depending on what angle the car is on, chances are that your coolant is low.
    if your sitting at traffic light and the temp starts going up, then goes back down when you rev the car (take off, or free-revving) your coolant is low.
    if it goes up and up and up and doesnt go down at all, youve got no coolant, or BHG.
    the EXTREMELY basic version of it.
    Elmo.
    W.A.
    what happens when you just started the car early in the morning and it does it and when you drive along a flat road and it does it
    Western Aus
    id say low coolant.
    check it, if its not that, have a hard look at wiring.
    Elmo.
    I also have had this happen with low coolant, check it out
    W.A.
    na coolant levels havn't changed in 6 months and still looks new
    Junior Member Backyard Mechanic leso's Avatar
    Ryan....dont forget the wiring runs from the gauge...problem could even be behind the gauge just a late night thought ...up watchin the moto gp
    W.A.
    well i sprayed it with some wd40 and fiddled with the wiring and took it for a drive, temp stayed about 1/4 the way and didn't bounce so see what happens tommorrow if it stays the same
    sux as a Grease Monkey
    coolant can't change temp that fast, and if it did the sender couldn't respond quickly enough. The problem is most likely electrical. If you've been playing around with the thermo housing then check wires for insulation breaks.
    89 ST162, Extractors, Muffler, Suspension, Intake, white dials. More to come when I get money...
    Originally Posted by Javal
    ...squeak like a rat in a microwave...
    I've had this happen once. I put it down to a bubble in my coolant. I checked the wiring, AOK. I never saw it again either.
  1. 18RGEU after market Temp gauge
    By normo in forum Tech and Conversions
    Last Post: 14-10-2006, 07:34 AM
  2. Temp Gauge Problems
    By Ghostrider in forum Tech and Conversions
    Last Post: 12-09-2006, 06:55 AM
  3. Blitz Exhaust Temp gauge wiring
    By 1200det in forum Tech and Conversions
    Last Post: 08-06-2006, 04:56 PM
  4. Water temp gauge install
    Last Post: 21-02-2006, 10:45 PM
  5. RA/TA2x oil temp gauge sender..
    By celica-fiend in forum Tech and Conversions
    Last Post: 30-01-2006, 12:57 AM
