Results 16 to 17 of 17
Thread: Are 3sge beams motors interference motors?
    Canada
    Default Re: Are 3sge beams motors interference motors?
    Pull the valve cover and look at the valve clearance. If it it way too big, then that is all the "proof" you need.
    Rough luck, hope it doesn't cost too much!
    Junior Member Domestic Engineer MRMOPARMAN's Avatar
    vic
    [QUOTE=mic*]I would concur, but there is no particular reason to think in this instance that a low compression reading would be to do with rings or lands. If its low, its gonna be a valve issue. QUOTE]
    a leak down tester will tell you if the valves are leaking and whether inlet or exhaust side are doing it, not only ring/piston leakage, and it will tell you how much they are leaking
  1. 3SGE differences?
    By Ashe in forum Tech and Conversions
    Last Post: 04-04-2007, 05:46 AM
  2. Beams 3sge Rwd
    By gwh1946 in forum Tech and Conversions
    Last Post: 02-12-2006, 08:32 AM
  3. BHG on beams 3sge (anyone want to make some $$ in VIC?)
    Last Post: 25-02-2006, 03:25 PM
