Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
Thread: sr20 conversion into ra28
    Junior Member Backyard Mechanic bigmat's Avatar
    sa
    Default Re: sr20 conversion into ra28
    no i dont have a thread. will get there. problems i am having are with the roll cage as i know with classic adelaide, next year you need to have side intrusion bars in place. that beening it will be hard to get a full cage through regancy park(our road authorities) here in sa. my engineer said we could do it but my rollcage guy said there wont be enough head room. all fun and part of it all.
    will post pics this week.
    Bumble Bee Cross Backyard Mechanic sleepin22's Avatar
    Quote Originally Posted by TA-022
    You've a very arogant opinion i've noticed. It's a thread asking for opinions and advice and this is what Rod has done. Also mentioned in his posts are fitment ideas and how it would and wouldn't work ... which isn't 'slamming' and isn't 'discouraging' its informative.
    Please note: this thread topic is titled "sr20 conversion into ra28". Its not " possible ra28 conversions". If you consider me arogant about this conversion, then its rightly so because I have done it. Twice. Which is Twice more than 99% of you on here. Join in this discussion by all means, but you make my abs sore with your foot in mouth comments. Yes, Rod has some good technical advice but he has also been hypocritical.
    Quote Originally Posted by sleepin22
    George,
    I think the chip on your shoulder may obscure your vision.
    BigMat,
    A common way to get around the roll cage issues is to get a half cage installed and engineer (Regency) approved and just add the front hoops and side intrustion bars for when you need them. That way you can have a weld in or bolt in rear cage and just have the front part as a bolt in.
    Looking forward to seeing the pics.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    sa
    didnt know they could do that. cheers. bolt ons. i thought it had to welded in.
    I went the other way and put a 3SGE (Gen 2) in my Datsun 1600. After going through all the pain of the RWD conversion, I can understand why you'd want to go for the Nissan motor that comes in a RWD configuration.
    However I think if you were to spend the time and money, a 3SGTE could probably be made to go harder than an SR20. There are several areas in which it is technically superior. The SR20 has rocker arms that limit the revs, and the alloy block can flex under extreme pressure. The CA18 is worth looking at too though, as it doesn't have either of these problems.
    But there are just so many cheap after market hot up bits for the SR20DET (and also the CA18DET) for RWD that they are pretty hard to go past for a reasonably cheap go-fast project.
    I had some experience with all of these motors as I currently have an S15 Silvia with a SR20, a S13 with a CA18DET and I've had a 3SGE in a Datsun 1600.
    If I had a pile of money to spend, I'd go for the 3SGTE. Working to a limited budget for a front engine RWD, it would have to be one of the Nissan engines and the SR20 is probably the easiest.
    Sort of OT but what about an ej20t? Fair bit of aftermarket support and are in the same vein as the sr20 and 3s motors. They can also be had fairly cheaply.
    Anyone done it before?
    New Zealand
    The boxer configuration of the Subaru motors makes fitment between the chassis rails VERY difficult and generally not cost effective.
    Callum
  8. #38
    edited......
  9. #39
    rahhhhhhhhh haha
  10. #40
    Quote Originally Posted by WDE_BDY
    Callum
    Fair enough. Just curious.
  11. #41
    The FJ20 is a strong motor and great for making BIG power.
    But they're getting pretty ancient now and harder to find and after market support for them isn't so great now.
    Also they weigh a ton compared to SR20 and 3SG, so you're going to get handling issues.
  12. #42
    I know nothing Grease Monkey damian's Avatar
    Feb 2010
    bit of an update on this one - bigmat won toyoshow in adelaide last month with his RA28 with the SR20 in it.
    also won the dyno shootout, entrants choice, and a few other awards.
    cleaned up basically!
    entrants choice says a lot for what toyota addicts thinks, yes we love our toyota's, but it seems most of us respect the work that went into it.
  1. RA28 stering rack conversion (need advice)
    By bullitt in forum Tech and Conversions
    Last Post: 20-08-2014, 10:37 AM
  2. Voltage reg on an RA28 for 1g conversion.
    By thomasbl in forum Tech and Conversions
    Last Post: 27-03-2006, 01:03 PM
