Results 16 to 20 of 20
Thread: Charcoal canister lines
    Default Re: Charcoal canister lines
    it is 1 way into the 'T"peice at bottom of canister (look at the pic in my second post) so it would allow boost in , some how I don't think its boost related
    Manny can you check on your car if there is another line coming from the bottom of the canister (it will still be in the engine bay) that has a 1 way valve on it, where does it lead to?
    Quote Originally Posted by rogue-vl
    so why is there a 1 way valve?
    This is pretty straight forward dude. I'm not having a go at you, but why are you experiencing so much heartburn over it?
    Vent at the bottom;
    larger line to the fuel tank (one way as explained by thechuckster); and,
    smaller line to purge to manifold.
    That's it. Done.
    Peter
    Junior Member Backyard Mechanic manny's Avatar
    Yes like in your last pic, there is a T section with the short upward run of hose and one way valve on the end. It's seated in that rubber grommet attached to the bracket for the canister. Nothing is attached to the end of it.
    My understanding is it's designed to allow air to be sucked in from the engine bay through the one way into the cannister when needed but not the other way so no fuel tank vented gases/liquids make it into the engine bay but rather out the purge port underneath the crossmember.
    GSE20 IS250 - daily
    OK I just didn't think it would be connected to nothing.
    Ok no more questions.
    Thanks guys
  1. DIY fuel and brake lines
    By Norbie in forum Tech and Conversions
    Last Post: 08-04-2007, 08:53 PM
  2. Garrett Turbo coolant lines
    By NAJJE in forum Tech and Conversions
    Last Post: 27-03-2007, 08:15 PM
  3. Aristo people - where is the charcoal canister mounted?
    By DLA11D in forum Tech and Conversions
    Last Post: 21-02-2007, 07:48 AM
  4. Fuel smell under boost/cruising mz20 7mgte
    By Kedderz in forum Tech and Conversions
    Last Post: 19-01-2007, 07:51 AM
