Results 16 to 17 of 17
Thread: a/d convertor for creating L1, L2 and L3 outputs for the auto ect
    vic
    Default Re: a/d convertor for creating L1, L2 and L3 outputs for the auto ect
    use a much simpler ecu like a 4 cy camry one or a 4YE tarago one , smaller size ecu . give it the throttle positon and rpm ,
    Or use a throttle sensor off a sv 22 camry , this has the L 1,2,3 direct out of the sensor , no ecu to use then ,
    Dave
    Conversion Master Grease Monkey Whiplash's Avatar
    wa
    Quote Originally Posted by cambelt1
    Dave
    yer i was thinking of using the camry type but i didnt know what vehicle it came off. cheers for that info as im going to go grab myself one just incase what im doing now with programming the picaxe doesnt go all to plan.
    the only problem with replacing the tps is that im pretty sure the signals for the other types have all changed. so the 2jzgte ecu wont be getting its signals anymore.. but im sure ill be able to work something one.
    does the camry ecu and such work in the same manner with 2 solinoids?
    cheers for the heads up
    shanon
  1. 4agze TPS - fault & setup
    By AE101LEV in forum Tech and Conversions
    Last Post: 24-10-2006, 06:36 PM
  2. TPS Problem
    Last Post: 28-04-2006, 02:10 PM
  3. TPS Idle Switch
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 19-03-2006, 05:44 PM
  4. Urgent Help Please - TPS - Car Undriveable !
    By ra23celica in forum Tech and Conversions
    Last Post: 10-03-2006, 10:40 AM
  5. Full-variable output TPS - what cars ??
    Last Post: 20-02-2006, 11:59 AM
