Results 1 to 5 of 5
Thread: lazy auto
    serial biochemist Automotive Encyclopaedia
    Default lazy auto
    I recently purchased an RA40 with a 3 speed auto box that is quite lazy. It takes longer than normal to go into reverse and doesn't feel like it's properly engaged in drive when I take off at first (does engage properly within a few seconds though). I'm going to dump the trans fluid when I do the rest of the oils this weekend but I wonder if anyone has any explanation for this sort of behaviour?
    please don't submit posts telling me to do a auto-->manual swap, we're talking about a $400 car that's being used to get from A-->B only.
    your rep rating is not a reflection of your worth to the community
    Quote Originally Posted by H1TMAN
    wtf? I want to do track racing, and f#@k you...
    that's very flattering but no thanks.
    Default Re: lazy auto
    Most auto problems are related to fluid, it might not have enough in there
    I think those also have a kickdown cable which needs to be adjusted correctly for the auto to kick down gears as it should... but that should have nothing to do with reverse so I'd be thinking it's more likely fluid related
    See how it persists after you change the fluids on the weekend and go from there
    I am the sun
    Junior Member Backyard Mechanic pAuL's Avatar
    the hesitation to get into a gear sounds like fluid, i had that problem with my auto lancer, just filled it up and no problems (as dale already pointed out)
    Current - 2006 Colt Ralliart 100.2FWKW@6000rpm,
    Past - 1988 Toyota Camry V6 (Sold) (VZV21) 117kw@5600rpm, 1994 Lancer Station Wagon Executive (sold) (86kW+@6000rpm), 1986 Corona S (sold) (73kW@4800rpm), 1990 Cressida GLX (BHG) (142kw@5600rpm)
    Aug 2006
    Smile Re: lazy auto
    Our camry was behaving in a similar manner, particularly with reverse.
    A fluid & filter change cured it, no probs since I did it 12 mths ago.
    Cheers.
    good call guys, the fluid was back and thoroughly f*$ked out. With the new fluid it changes like new. Cheers for the replies
  1. Auto build shopping list
    Last Post: 25-01-2007, 07:40 AM
  2. auto ecu runing manual car
    By sam-131 in forum Tech and Conversions
    Last Post: 06-05-2006, 12:56 AM
  3. GZ20 auto to maunal conversion
    By Big rob in forum Tech and Conversions
    Last Post: 03-03-2006, 06:15 PM
