Results 16 to 23 of 23
Thread: Has anyone here built a GE/GZE hybrid?
    Default Re: Has anyone here built a GE/GZE hybrid?
    itd be around there, ive got one hanging up in the shed at home ill have a look at th elength when i get home.
    Nurses rock! Grease Monkey lunar_c's Avatar
    Feb 2007
    You're a champ toof
    New Zealand
    my aw11 was running a 4age redtop bigport with aw11 4agze setup.
    went very very well, especially when used with the c52 box. higher comp = more hp, better ratios = faster faster!!
    as stated all lines up and works very well. be sure to use the best fuel you can.
    i was running timming at 8 deg on 95 octane with no problems
    the biggest issue is the bigport has no boss for the knock sensor. and no knock sensor = fault code and lack of power.
    so i made up a bracket to fit two unused holes in the block and fitted a sensor to that
    http://s3.photobucket.com/albums/y82/Mr-Revhead/aw11/
    works perfectly. installed pic is taken from behind and under s/c you can see the main water pipe that runs from back of pump to thermostat housing.
    its bolted in so the lower edge is held solid against the ribs. you have to make sure it cant move or vibrate.
    please, no more PMs!
    my current 4agte is my original 4age block, the boss for the knock sensor was there, same spot on the block as the 4agze had it, just no hole. so i drilled and tapped a thread there for the knock sensor.
    New Zealand
    oh ok, well i cbf taking my engine out to do it
    so i did what i did
    i never removed the engine, did it in the car.
    cut a couple drill bits in half and resharpened them so i could get the drill in against the firewall.
    New Zealand
    bloody hell.
    i didnt have the tools to fit in there! lol
    so, you have 2 solutions
    main thing is, FIT A KNOCK SENSOR
    Junior Member Backyard Mechanic Wedged'86's Avatar
    Jun 2006
    Yeah i looked into this a while ago too and found what i wanted to hear.
    Do you plan to have a switch for the supercharger Mad Max style????
    cause that's the way.
  1. 2tg/3t hybrid - the next step?
    By byrnziecelica in forum Tech and Conversions
    Last Post: 15-08-2006, 08:35 PM
