Results 16 to 30 of 44
Thread: 2JZGE Waterpump onto a 1JZGTE...who has done it?
    Junior Member Backyard Mechanic manny's Avatar
    Default Re: 2JZGE Waterpump onto a 1JZGTE...who has done it?
    JZA80 Supra 2JZ-GTE / JZZ30 Soarer 1JZ-GTE Water Pump (Viscous/non-hydro)
    Part number 16100-49846 for which I paid $119.20 from Penrith Toyota with club discount in January 2005
    JZA80 Supra 2JZ-GE / JZZ31 Soarer 2JZ-GE Water Pump (viscous/non-hydro)
    Part number 16100-49837
    JZZ30 1JZ-GTEs never left the factory with the combo hydraulic/water pump - they were found on JZX90 Chaser and JZA70 Supra 1JZ-GTE factory engines.
    A few pics of the JZA70/JZX90 Combo Hydraulic/Water Pump
    GSE20 IS250 - daily
    UZZ30 Soarer - 1UZ-FE/R154/Adaptronic - trackday roughie
    UZZ32 Soarer - Active Hydropneumatic Suspension (A-SUS) & Active Four Wheel Steering (A-4WS) - cruiser
    Quote Originally Posted by manny
    Excelent, I was suspecting that the JZZ30 was the same as the JZA80.
    I'll PM the ppl with pics asking for stuff shortly (read a week or two ).
    Yeah, the pump is still around $160, but the pulley makes up the rest of that slack, and is around $160 on its own. I phoned up a while ago enquiring about this for another friend and the P&S wouldnt give me trade, so retail on the pump was like $190 and pulley was about $185 :S
    Junior Member Grease Monkey ripfast's Avatar
    1G-GTE pulley also fits.
    Quote Originally Posted by ripfast
    I call BS on that one. petespipes had what was claimed to be a 1ggte pulley sent to him, and I physically held both in my hand. The PCD for the bolt pattern's and size is all wrong. Do you have first hand experience that I'm unaware of? (I'm not 100% sure that it was a 1ggte pulley so I maybe incorrect)
    [cash in] I sell 2JZGE pulleys for $85 + postage. [/cash in]
    listen to the man! you save $100, and the only difference is you need to give it a $5 lick of paint
    problemo...I need it tomorrow...and the trade order has already been placed
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    BK Grease Monkey bk_'s Avatar
    Quote Originally Posted by mrshin
    $160 sounds very close to what I paid from there too...
    As for the pulley, I had a JZX81, JZZ30, and JZA80 engine all kicking around, and I can't actually remember which pulley I used.... But one of them fitted.
    I had to replace the JZX81 pump since it also is a hydraulic one aswell.
    160$ is how much I paid (trade price) 6 months ago. or ~$190 full price.
    I got the JZZ30 pulley from a fellow toymods member for 40$
    My only minor gripe about the pump is that the studs at the rear of the pump (that connect to the stainless steel pipe) are _barely long enough_ for the nuts to screw on. Not sure if it was only my pump, or it's common for all of them.
    -BK.
    West Australia
    BUMP!!!!
    back to the future from 2006 !
    Got told today by a exclusive , usually quite intelligent parts store that their aftermarket version of the 2JZGTE/GE pump fits.
    and i was told the GE version of theirs is same as GTE
    can anyone remember what the EXACT problem with the GE version that causes them not to fit a GTE engine ?
    <3
    I suspect the front section / pump bit is the same.
    The rear section isn't tho.
    Yah, rear is different, front is the same.
    West Australia
    and the front section of 2JZGE will not bolt to 1JZGTE rear housing ?
    QFTT. 2jzge front will bolt to 1jzgte JZZ30 rear
    I'll take some pics for you when I get home.
    In short
    xJZ-GTE rear section from NORMAL water pump (JZZ30, JZA80)
    xJZ normal water pump front section and pulley.
    West Australia
    so 2JZGE front is compatable with 2JZGTE/1JZGTE (non hydro) rear which is compatable with 1JZGTE engine from Z30 or A70
    But if the 1JZ/2JZ has hydro rear, that must be replaced with 2JZGTE/1JZGTE non-hydro rear
    excellent
  1. 2JZGE into MX83
    By rvrolla in forum Tech and Conversions
    Last Post: 21-05-2007, 09:16 AM
  2. 2jzgte cams in 1jzgte do they fit without mod
    By 1JZ.747 in forum Tech and Conversions
    Last Post: 12-01-2006, 08:54 AM
  3. 1JZGTE Age
    By WindeX in forum Tech and Conversions
    Last Post: 06-01-2006, 08:52 PM
