Results 1 to 10 of 10
Thread: 1j microtech lt12+xf throttle body q's
    Aug 2006
    Default 1j microtech lt12+xf throttle body q's
    im looking to put a bigger throtle body on my 1j and im thinking ford xf 68mm.
    my 2 main concerns are how much modification i have to do to the factory inlet manifold,ie do the bolt holes line up?
    and what mods do i need to do for the microtech to read the ford t.p.s?
    microtech is an lt12s
    anyone put a bigger throtle body on their 1j?
    thanks for any advice
    yann
    Default Re: 1j microtech lt12+xf throttle body q's
    firstly, why do you want to upgrade? What turbos and boost are you running?
    If the ford TPS has a ground, power and 0-5v signal then the microtech will read it.
    QUICKEST 1JZ'S IN OZ
    Aug 2006
    hey chris,turbo is a 35r .82rear,im using 80mm intercooler piping and then it goes down to that little throtle body,it looks like a restriction and im hoping ill get better throttle response with a bigger throtle body?
    dont need 80mm piping mate, way overkill...
    bigger throttle body will decrease throttle response. You could upgrade if you want. 1jz747 was making around 580rwhp with the stock throttle body and plenum though.
    Aug 2006
    ok so it sounds like a pointless modification then
    id think 2.5inch pipes would even do some good rather than harm.
    Montrose
    Throttle will not quite bolt up; you'll need to redrill and tap the holes. As said, there really is no point in using it though.
    just remeber u will be replacing a 90's model toyota part with a early 80's ford part
    have heard of nothing but problems with those XF throttles
    good for a cammed up RB30 and thats about it
    The boobs are back
    Quote Originally Posted by Mr DOHC
    same here.. the TPS's seem to be absolute crap..
  1. 3sfe throttle body help
    By jezza323 in forum Tech and Conversions
    Last Post: 09-04-2007, 08:31 AM
  2. can you have a throttle body thats to big?
    By slide86 in forum Tech and Conversions
    Last Post: 05-10-2006, 06:15 AM
  3. Throttle body change, vacuum leak?
    Last Post: 25-07-2006, 06:15 AM
  4. Replies: 24
    Last Post: 18-04-2006, 01:42 PM
