Results 1 to 10 of 10
Thread: rear wheels locking underpower
    Crazy 1st year Apprentice
    Default rear wheels locking underpower
    Hi All,
    Bit difficult to diagnose with words but I would appreciate some help. Today while taking off from the lights up a slight slope the rear wheels started locking (skidding and hopping) only when accelerating, in all gears, it appears not to be speed dependent but I was unable to get above 30km/h. Pulled over to check. no visible damage. half shafts appear fine. It only happens in forward. I was able to drive in reverse with no locking. I was able to coast forwards with clutch in, no locking. I was able to coast forwards clutch out, in neutral no locking (didn't try in gear with no power but gearbox is not making any abnormal noises). It is a clutch pack LSD diff. My guess is one of the pins that holds the spider gears/clutch pack has broken and is centrifuging out of place under accel and locking against the casing. Any other suggestions would be appreciated? before I pull the diff for a look on Sunday.
    BMW e30 327i Motorsport
    under construction
    ZZR1100 single seat hillclimber
    nocost7
    Default Re: rear wheels locking underpower
    the only thing I can think taht would be is the diff.. crack it open and the problem will probably become obvious
    thanks Draven, that was my suspicion. I'm guesing there will be a bit of a mess in there when I do get the cover off.
    under construction
    nocost7
    hehe
    u broke it
    pics or ban
    Junior Member Backyard Mechanic SIKTOY's Avatar
    I had a similar problem in my 23 it had a cracked crown wheel
    So yeah you fucked it ha ha ha
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
    I would love to eat a... Domestic Engineer Sagluren's Avatar
    south australia
    now that is not very nice, everyone laughing at the poor sod,
    but yeah it seams fubared
    sam.
    Thanks all I don't mind my misfortune being laughed at, I wish I broke it in a more exciting situtation than taking off at lights. I knew I broke something and I just wanted to confirm that everyone thought it was the diff before I pulled it out. Any way I got it out last night and am cracking it open later today. Q for SIKTOY did your cracked crown wheel damage the input pinion gear?
    craig
    under construction
    nocost7
    Even if the pinion gear looks ok you will need to replace it. If not there is a good chance it will be noisy and wear out really quick. The pinion and crownwheel are a matched pair and should be kept together.
    south australia
    you will find that the pinion and crown wheel, will both have an id number, these should not be interchanged as stated above.
    sam.
    yes yes, crown wheel and pinioin shaft are a matched pair.
    dont fuck with them.
    and for what its worth, i found out today i have cracked teeth on my crown wheel, this diff under my ke70 is out of a 1971 alfa romeo....im farked
    more fucking money i dont have. so cut right now...
    By The Witzl in forum FAQ
  2. Suspension for dummies
    Last Post: 13-09-2007, 08:38 PM
  3. T series rear end diff centre change guide (warning, pics!)
    Last Post: 31-05-2007, 12:57 AM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
