Results 1 to 15 of 17
Thread: 3VZ-FE in Camry not Firing
    Hide Yo Kids Hide Yo Wife Carport Converter hamgatan's Avatar
    Default 3VZ-FE in Camry not Firing
    Hi
    Trying to pull some engine codes out of my gf's mums car.. but I am not sure which terminals to bridge in the diagnostics panel.
    Symptoms, it turns over, there seems to be electrics going through the injectors + spark leads (tested them all with a multimeter), but wont fire. Ideas?
    Its a VZ series Camry. 1994 or 95 i think...? 3VZFE.
    Chris
    JZZ20 1988 Soarer GT Twin Turbo
    1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
    Junior Member Backyard Mechanic pAuL's Avatar
    Default Re: 3VZ-FE in Camry not Firing
    just about the only thing i know about those engines is they do head gaskets
    sorry couldn't help
    Current - 2006 Colt Ralliart 100.2FWKW@6000rpm,
    Past - 1988 Toyota Camry V6 (Sold) (VZV21) 117kw@5600rpm, 1994 Lancer Station Wagon Executive (sold) (86kW+@6000rpm), 1986 Corona S (sold) (73kW@4800rpm), 1990 Cressida GLX (BHG) (142kw@5600rpm)
    wa
    bridge te1 or te and e1 on th diagnostic plug under the bonnet to get the codes
    hmmm thats what i did and the engine light kept flashing and didnt stop... it was going well past 150 flashes before i stopped and went 'does it really flash that many times?
    does it have fuel
    or fuel pump working
    If it just keeps flashing, thats the code for - No codes. So you havent got a ECU recorded fault.
    First thing id do on GF's mums car is pull the air filter out... You may be surprised. If not;
    Test spark by pulling a lead off and witnessing spark jump to head - which it sounds like you've done.
    How have you tested injectors? They have constant power when Ig is on, and it is not definitive to tell if they are injecting fuel by just checking power to them.
    I would suggest testing fuel pressure. If you dont have a gauge you can do it crudely by pulling off the fuel return line after the FPR (fuel pressure reg). Then crank the engine with something to collect the fuel that should flow from the return. This will tell you that you have a good working pump, & filter/lines are not blocked... It does not rule out that your FPR might be stuffed but i have never (EDIT: once in a r31 skyline) had one fail yet.
    meh...
    Junior Member Backyard Mechanic Jaemus's Avatar
    afaik, you can test the injectors by pushing the AFM flap in with the ignition on, they will start squirting.
    you def need to witness a spark, it could be the dizzy, coil, igniter or the wiring for those.
    1992 MR2 GT turbo
    2009 Lexus IS-F
    Built Australia's first V6 MR2 >> Winner: "I'd Drive It" award - Toyfest '07
    Quote Originally Posted by Jaemus
    those widebody camrys do a lot of ignition problems as well i've done many a dizzy, idle control, TPS, coil, ignitor, lead etc for them... they become apparent anything around150,000 kms onwards... good luck with it, my money's items i've mentioned
    Western Aus
    sure the spark plugs arent assed?
    Elmo.
    well believe it or not i tried getting to them.. that was one of my first guesses coz it cranks over, i can smell fuel being injected.. but gf's dad is an arrogant shit. hes like 'theyre only new.. its not the spark plugs'. and didn't want to hear anything differently... and thinking hes Mr Mechanic pulls off the cam cover to look at the timing belt..with me sitting there in the background shaking my head going, u idiot..
    i tested the injectors, well the front 3 anyway, they all had 12+v going through them.
    i gave up. its like trying to communicate with a brick wall, especially when mr stubborn just has to re-enforce his position as the man of the house being a know it all. i asked him to pull a plug out for me to test.. he stomped his feet in a tantrum and said 'thats not the problem'
    they can fix it themselves now as far as im concerned. guess hes just afraid id outdo him at something..
    Western Aus
    well fuck him then, go home, invite me over and have beer in fridge.
    that is all.
    Elmo.
    i know this sounds evil. but i hope the camry gets up and running again and gets arse ended in a writeoff.
    reason?
    coz its the cleanest 3VZ-FE i've ever seen, it seriously looks like a brand new showroom car under the hood.
    would look smashing in the MR2... right Jaemus?
    get yr gf preggy then he might start being nice to u
    heheh
    get a long flat blade screw driver
    sit blade end on injector then blunt end on yr ear
    crank engine see if u hear clicking if so then u have fuel
    or u can buy some aerostart and see if it runs on it
    then remove a spark plug lead and test for spark
    its only a small zapp so dont be a wuss
    hamgatan - damn right! find some reason for them to park it in the street, then come along at night with an old truck sporting a massive bullbar, and write it off for them
    * note: i do not condone anything i say
    1992 MR2 GT turbo
    2009 Lexus IS-F
    even if the plugs are caked up, it's highly unlikely all 6 are so fucked they wouldn't work... still i'd check for spark to eliminate this fault..
    pretty sure it takes an asian know-it-all to convince an asian know-it-all dad.. but that's just me... i have trouble convincing the typical bloke my point of view sometimes..
  1. camry issues
    By Pr0j3kt_SuPrA in forum Tech and Conversions
    Last Post: 06-01-2007, 03:14 PM
