Results 16 to 17 of 17
Thread: 3VZ-FE in Camry not Firing
    T'ville, QLD
    Default Re: 3VZ-FE in Camry not Firing
    check for earth!!!! i had these problems with the 20v and i got new dizzy cap and rotor button and leads and u know what was wrong? fucking earth, check that before going any further, and tell ur gf's old man to check for exhaust leaks or some shit like that, to get him outta ur hair.
    2T out 4A in....
    VZ engine series FTW! Grease Monkey Timma's Avatar
    May 2006
    I'd be checking everything ignition related if you can hear the injectors pulsing and can smell fuel, Start with rotor button for cracks and dizzy cap. Ignitor, test the resistance across the primary and secondary coils. Also hold the lead to the strut tower crank the car and test for spark. Dizzy, check for loose bolts, check pickup coil resistance, check gap. Also if you keep cranking the motor this might foul the plugs. If you've already got the plenum off its wise to change the plugs anyways. Thats all I can thing about for now.
    vzv21 camry 2vzfe v6 - aka mr burble or white one
  1. camry issues
    By Pr0j3kt_SuPrA in forum Tech and Conversions
    Last Post: 06-01-2007, 04:14 PM
