Results 1 to 9 of 9
Thread: KE70 Sway bar
    Default KE70 Sway bar
    I am looking for a sway bar for my ke70 and the sizes avaliable are not that exciting. Does anyone know if a ae86 front sway bar will fit a ke70?
    That dude with the AE95's Backyard Mechanic Kebin's Avatar
    Constitution Hill, NSW
    Default Re: KE70 Sway bar
    I dunno about the front but i heard rear way bars from a tercel bolt into *e7* corollas and are something like 17mm. I am keen to see if it is true..
    Rosewood
    run twin swaybars
    Mad****** Grease Monkey FASTFOO's Avatar
    vic
    One word panelvan check them out
    MATT.
    I did have a heavy front sway bar for a KE70. Think it was 24mm.
    Vague memory tells me I sold it a while back, but can check over Easter. Also had a rear, but think thats gone too.
    Pretty sure it was a Pedders bar, so check them out.
    Junior Member 1st year Apprentice ArJay's Avatar
    The Whiteline front swaybar will bolt up directly to a KE70/AE71.
    There's one in my AE71 as we speak. Swapped it straight over from my old 86...
    Pretty much all suspension stuff is interchangeable minus the front strut inserts. The 86 has larger diameter front struts. Rear shocks, springs etc etc all fit....
    Rory
    Keep it Low and Slow
    AusZoku
    south australia
    ok this is by deductions:
    TA-022 has a ae86/ke70 front cross member in his car
    the control arms of a standard ae86 are the same as an ra28 ie30cm
    there are 2 swaybars that i know of that are 24 mm upgrades over standard sizes
    an upgrade for Nath's setup of ae86 rack using i assume to be standard 30 cm control arms was a bar from a t-18.
    as this was a direct replacement for the ra28 bar, this would mean an ra28 bar could fit also.
    as ra28 is the same as ra40 front then the standard upgrade for an ra40 is MX62 courtesy of Brett_celicacoupe (and i have also verified this by fitting one to my ra40).
    SO.... try an MX62 or T18 at the local wreckers and see how close it fits, both are 24mm and both would be a hell of a lot cheaper than whiteline/red ranger or whatever they are called now.
    ^^^^^^ good post bro!!!
    CSI Toymods...
    AusZoku
    $35 from local pick a part. 24mm and fits so beautifully!
    ra28 arms ke70 crossmember and rack MA61 Manual Column.
    nice deductions barned01!
    Black Betty >HERE!<
    (\__/)
  1. KE70 Panel Van Dash
    By Gleno28 in forum Tech and Conversions
    Last Post: 23-04-2010, 12:21 PM
  2. 1g-gte front winged sump into TA23 Sway Bar issues!
    By hemi twofifteen turbo in forum Tech and Conversions
    Last Post: 21-09-2006, 10:08 PM
  3. Ke70 4age
    Last Post: 09-09-2006, 01:32 AM
