Results 16 to 26 of 26
Thread: 20v rev limiter
    Default Re: 20v rev limiter
    the ozclubbie guys use a 555 timer to gernerate a constant ground pulse signal to raise the revlimit when they dont have a pulsed output from the speedo.
    Junior Member 1st year Apprentice boon280's Avatar
    Apr 2007
    S.A
    has anyone got a diagram of how to wire one of these into my loom?
    This is the 555 timer circuit that Richard (LMR052) on Ozclubbies came up with, apparently several of the guys are using this circuit successfully.
    Julian.
    tasmania
    Also correct me if im wrong error 14 is an ignition code eg. no igf signal..
    Apr 2007
    S.A
    Quote Originally Posted by FMS01
    Julian.
    Thanks for this I just took this diagram to my electronics guru and he will have one built in a few days, He said everythink looked like it will work fine.
    Thanks for your help.
    apparently it should be able to be built small enough to fit into a plastic film cannister (does anyone still have these??)
    Julian
    Apr 2007
    S.A
    yeah the guy doing it is going to put it a standard 12v relay case like you would use on your spotlights or something like that.
    so it should be pretty neat.
    Jun 2007
    Smile Re: 20v rev limiter
    Hi Guys,
    have had this cct built and works a treat. It gave my 86kw Bluetop engine an increase in revs from about 6700 to 7500. Don't know about the top end speed limit as yet because I haven't been on a track that will let me get to this speed - Normally I do Hillclimb events.
    Nice small unit that fits basically in a matchbox size plastic box.
    thanks for your knowledge transfer....
    Alex.
    N.S.W
    Quote Originally Posted by Alex63
    Cool, i thought the 16v 4AG's were limited to 7200.
    Does the 7 rib bigport have the same rev limit? If so, I'll have have to make one of these for sure!
    Good. Fast. Cheap.
    Pick 2.
    Junior Member 1st year Apprentice Fred_SPb's Avatar
    Apr 2007
    Saint-Petersburg
    Quote Originally Posted by robakka
    Right, 14 - Ignition - No IGF signal to ECU for 4 consecutive IGT signal during engine running - Open/short in IGF/IGT signal from igniter to ECU, Igniter malfunction, ECU
    If ECU has no IGf signal - it not pulse injectors, to prevent cat overheating.
    Aug 2007
    Alberta
    Quote Originally Posted by sideshow
    join spd to #10
    That has got to be one of the most inventive modifications i've ever heard. This should in theory work on almost any Toyota vehicle.
  1. Why is my 2jz-gte hitting rev limiter?
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 11-10-2006, 02:39 PM
  2. 1JZGTE problem, rev limiter/ idle
    By GZP51 in forum Tech and Conversions
    Last Post: 24-09-2006, 04:38 PM
  3. Using Jaycar Rev limiter as "valet mode"
    Last Post: 17-04-2006, 11:33 AM
