has anyone got a diagram of how to wire one of these into my loom?
				the ozclubbie guys use a 555 timer to gernerate a constant ground pulse signal to raise the revlimit when they dont have a pulsed output from the speedo.
				Also correct me if im wrong error 14 is an ignition code eg. no igf signal..
Originally Posted by FMS01
Thanks for this I just took this diagram to my electronics guru and he will have one built in a few days, He said everythink looked like it will work fine.
Thanks for your help.
				apparently it should be able to be built small enough to fit into a plastic film cannister (does anyone still have these??)
Julian
yeah the guy doing it is going to put it a standard 12v relay case like you would use on your spotlights or something like that.
so it should be pretty neat.
				Hi Guys,
have had this cct built and works a treat. It gave my 86kw Bluetop engine an increase in revs from about 6700 to 7500. Don't know about the top end speed limit as yet because I haven't been on a track that will let me get to this speed - Normally I do Hillclimb events.
Nice small unit that fits basically in a matchbox size plastic box.
thanks for your knowledge transfer....
Alex.![]()
				Cool, i thought the 16v 4AG's were limited to 7200.Originally Posted by Alex63
Does the 7 rib bigport have the same rev limit? If so, I'll have have to make one of these for sure!
Good. Fast. Cheap.
Pick 2.
Right, 14 - Ignition - No IGF signal to ECU for 4 consecutive IGT signal during engine running - Open/short in IGF/IGT signal from igniter to ECU, Igniter malfunction, ECUOriginally Posted by robakka
If ECU has no IGf signal - it not pulse injectors, to prevent cat overheating.
				That has got to be one of the most inventive modifications i've ever heard. This should in theory work on almost any Toyota vehicle.Originally Posted by sideshow
