Nah Not all GZE's have the squirters.
Have you tried the search function on this forum ? You should find plenty of info as it has been discussed numerous times.
The witzl's thread tells all.http://www.toymods.net/forums/showth...AE92+squirters
hey i have just opened both of my blocks one of which is a ae111 20 valve black top the other is a 4agze block. I was just slightly confused as i was under the assumption that the black tops never came out with squiters and the gze did. The reason i am asking this is cos the 20 valve does have squiters and the gze doesn't. Also i was just wondering what head gaskit to use as i am fitting the 20 valve head to a gze block any info would be really helpful thanks
What do oil squirters look like on a 7M engine?
Bumpity BumpOriginally Posted by amichie
they are lil tubes in the bottom of the cyl pointing up towards where the piston would be
Here is a 20V silvertop block showing the squirters....
OK
Thank you for that.
My rods have little oil squirt holes that seem to do a similar type of thing.
The little hole in the rod is designed to spray the cylinder wall on the thrust side of the cylinder. the squirters are designed to spray the piston bottoms.Originally Posted by amichie
